Energy required to ionize a hydrogen atom from n=1
The discussion revolves around the energy required to ionize a hydrogen atom from its ground state, using the formula delta E = chR. The initial calculation yielded an incorrect energy value of 1.36009026784583 * 10^{-37} eV, significantly off from the expected 13.6 eV. The error was identified as a mistake in the conversion factor from Joules to eV, where the exponent should be -19 instead of +19. Correcting this factor aligns the result with the teacher's answer. Attention to unit conversions is crucial in such calculations to ensure accuracy.
tony873004
We were given this formula in class:
delta E= chR (\frac{1}{1^2} - \frac{1}{inf})
the 1/1^2 is because it is in ground state. So the formula simplifies to
chR
c = 299792000
h = 6.626E-34
R = 10970000
and 1.60217653*10^{19} Joules / eV
I get:
The teacher did it in class and got 13.6 eV
Same answer, just 38 magnitudes off :eek:
What am I doing wrong?
** edit ** I figured it out. It's not 19, its -19 for Joules to eV
There you go:you have scientifically proven that 10^{-19} and 10^{19} are 38 orders of magnitude apart.Congratulations!
Daniel.
It seems like you have made a small error in your calculations. The correct conversion factor from Joules to eV is 1.60217653*10^-19 (negative exponent). When you use the correct conversion factor, you will get the same answer as your teacher, 13.6 eV. It's important to pay attention to the units and their exponents in calculations like this to avoid errors. Keep up the good work!
