Center of Gravity in a Horizontal Cylinder with Water
To find the center of gravity of a horizontal cylinder filled with water, the relationship between the diameter occupied by the water and the masses must be established. The problem is more complex than that of a vertical cylinder, as the calculations for the horizontal orientation differ significantly. It is suggested to approach the problem by determining the center of area under a chord of a circle, rather than manipulating vertical cylinder calculations. The formula for mass in terms of diameter and height is proposed, but clarity on the relationship is needed. Understanding the geometry of the horizontal cylinder is crucial for solving the problem effectively.
chinocr3
I need to find the center of gravity of a horizontal cylinder that has water in it, the level of water changes so I need to determine a relation between the diameter occupied by the water and the masses, those are my guesses.
I solved the problem where i have the standing cylinder where the C of G depends of the height of the water.
I added an attachment where you can see the formulas i used.
How can I make a similar relation with the horizontal cylinder?
Maybe using D as the variable instead of h?
m0 = ( (D2∏h)/4 )* ρ
where D2 = variable
and ∏h/4 = constant?
sorry if the answer is obvious, I'm really bad at physics $:
If the cylinder is on its side, try setting up the problem from scratch. I don't think trying to manipulate calculations for a vertical cylinder will be very easy.
The horizontal position is obvious so that leaves the vertical position...
You just need to find the center of area of the area under a chord of a circle.
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
Thread 'A bead-mass oscillatory system problem'
I can't figure out how to find the velocity of the particle at 37 degrees. Basically the bead moves with velocity towards right let's call it v1. The particle moves with some velocity v2. In frame of the bead, the particle is performing circular motion. So v of particle wrt bead would be perpendicular to the string. But how would I find the velocity of particle in ground frame? I tried using vectors to figure it out and the angle is coming out to be extremely long. One equation is by work...
