A rather difficult problem: deltoid inscribed into an ellipse
In summary, a problem was proposed in 1995 in the "Annual Iowa Collegiate Mathematics Competition" involving an ellipse and a fixed point inside it. The problem was to prove that a specific expression involving four segments is independent of the choice of perpendicular lines through the fixed point. The conversation discusses the difficulty of finding a solution using analytic cartesian methods and the search for a more elegant geometric solution. One participant suggests expanding the ellipse until it becomes a circle and using classical geometric techniques to prove the property.
lemma28
I'm a collage teacher and I've found a very hard problem in one of my math classrooms' textbooks. It was firstly proposed as problem n. 9, back in 1995, in the "Annual Iowa Collegiate Mathematics Competition". Link is here (no solution file available in the site for that year).
The text is rather simple:
Let E be an ellipse in the plane and let A be a fixed point inside of E. Suppose that two perpendicular lines through A intersect E in points P, P' and Q, Q' respectively. Prove that
[itex]\frac{1}{\bar{AP} \cdot \bar{AP'}}+\frac{1}{\bar{AQ} \cdot \bar{AQ'}} [/itex]
is independent of the choice of lines.
Practically there's a "deltoid" (a quadrilateral with perpendicular diagonals) inscribed into a generic ellipse and the property to demonstrate involve the four segments in which the diagonals are reciprocally subdivided.
Till now I've found that:
  • the property is actually true. I've seen that by empirical verification using Geogebra and following the cartesian analytic solution (see 1) outlined below;
  • using a cartesian reference system it's possible to prove the property, but with huge calculations (see 1);
  • drawing the tangent lines to the ellipse in the points P, P', Q, Q' they intersect in four points (say B, C, D, F). The diagonals of this new quadrilateral (this time circumscribed to the ellipse) meets too in the point A (!) (empirical but unproven discover using Geogebra - probably, the core of the yet unfound geometrical demonstration is connected to this fact).
Since I'm not satisfied with the analytical cartesian way (with huge calculations) and I don't think that was the proof intended by the people that proposed this problem back in 1995 and since I think there must be a clever and a more elegant geometrical way to it, I'm asking for some help to find a better solution.
I've also challenged my math students (aged 16-18, about 70 students) to find a solution to this problem, and I'm curious to see if a fresher (and just less experienced) brain than mine can find the right way when my purported experience isn't much helpful in this case.
1 Given the ellipse centered in the origin with equation [itex]\frac{x^2}{a^2}+\frac{y^2}{b^2}=1[/itex], a generic point [itex]A\left(x_A,y_A\right)[/itex] inside the ellipse (that is with [itex]\frac{x_A{}^2}{a^2}+\frac{y_A{}^2}{b^2}<1[/itex]) and the two perpendicular lines r: [itex]y=m\left(x-x_A\right)+y_A[/itex] and s: [itex]y=-\frac{1}{m}\left(x-x_A\right)+y_A[/itex] incident in A that intersect the ellipse respectively in the points P, P and Q, Q', after calculating the coordinates of the intersection points P, P', Q and Q' of r and s with the ellipse and the lengths of the segments AP, AP', AQ, AQ', then it is
[itex]\frac{1}{\bar{AP} \cdot \bar{AP'}}= \frac{b^2+a^2 m^2}{\left(a^2b^2-b^2 x_A{}^2-a^2y_A{}^2\right) \left(1+m^2\right)} [/itex]
and
[itex]\frac{1}{\text{AQ} \text{AQ}'}= \frac{a^2+b^2 m^2}{\left(a^2b^2-b^2 x_A{}^2-a^2y_A{}^2\right) \left(1+m^2\right)} [/itex]
so that
[itex]\frac{1}{\text{AP} \text{AP}'}+\frac{1}{\text{AQ} \text{AQ}'}=\frac{a^2+b^2}{a^2b^2-b^2 x_A^2-a^2y_A{}^2} [/itex] and this last expression doesn't actually depend on the coefficient m, that is on the choice of the two lines r and s.
Mathematics news on Phys.org
hi lemma28! :smile:
try expanding the ellipse parallel to one of the lines until AP.AP' = AQ.AQ'
then the ellipse will have become a circle (your students should be able to prove that easily!), and its diameter will be the diameter of the ellipse perpendicular to the direction of expansion
i haven't managed to finish it, but it looks as if a classical geometric proof should be possible :wink:
1. What is a deltoid inscribed into an ellipse?
A deltoid inscribed into an ellipse refers to a geometric shape where a deltoid (a triangle with three equal sides) is drawn inside an ellipse, with its vertices touching the ellipse at three different points.
2. What makes this problem difficult?
This problem is considered difficult because it involves finding the exact dimensions of the deltoid within the ellipse, which requires complex mathematical calculations and equations.
3. What is the significance of this problem?
This problem has significance in mathematics and geometry as it showcases the relationship between a deltoid and an ellipse, and highlights the intricacies of inscribing one shape into another.
4. How can this problem be solved?
This problem can be solved using various mathematical methods, such as using trigonometry, calculus, or algebraic equations. It may also require the use of geometric constructions and visual representations to better understand the problem.
5. What are some real-life applications of this problem?
This problem has applications in various fields such as architecture, engineering, and art. For example, it can be used in the design of bridges, buildings, and sculptures, as well as in computer graphics and animation.
  • General Math
  • Classical Physics
