Contact angle of liquid drop on solid surface.2
In summary, the surface tension direction is tangential to the surface, and it is important to consider the forces acting on the surface to determine the direction of the surface tension. The surface tension of a solid-air interface is also considered when balancing forces on a liquid because it affects the forces acting on the liquid-air interface.
amk_dbz
42
Can anyone explain point 44 of the attached pdf document on surface tension.
(Here's the link in case attachment doesn't work:
http://www.sakshieducation.com/EAMCET/QR/Physics/Jr Phy/12Surface tension _198-208_.pdf
How is the surface tension direction found out?
{i know it tangential but in which direction along the tangent?}
Also why is surface tension for Solid-Air Surface considered when balancing forces on liquid?
Any help will be appreciated
Thank you.
  • 12Surface tension _198-208_.pdf
Point 44 from the PDF states that the surface tension of a liquid is always directed along the tangential direction of the surface. This means that the force due to surface tension will be in the direction perpendicular to the surface. To determine the direction of the surface tension, it is important to consider the forces acting on the surface. For a liquid-air interface, the forces acting on the surface are the weight of the liquid, the pressure difference between the two sides of the interface, and the surface tension. The direction of the surface tension can be determined by finding the direction in which the sum of all these forces is equal to zero.The surface tension of a solid-air interface is also considered when balancing forces on a liquid because the surface tension of the solid-air interface affects the surface tension of the liquid-air interface. This is because the liquid-air interface is in contact with the solid-air interface and thus, the forces acting on the liquid-air interface are affected by the solid-air interface.
Related to Contact angle of liquid drop on solid surface.2
1. What is a contact angle?
A contact angle is the angle formed at the point where a liquid drop meets a solid surface. It is the angle between the surface of the liquid and the tangent to the surface of the solid at the point of contact.
2. How is the contact angle measured?
The contact angle is usually measured using a goniometer, which is an instrument that can measure angles. The drop of liquid is placed on the solid surface and the angle is measured using a microscope or a camera.
3. What factors affect the contact angle?
The contact angle is affected by factors such as the surface tension of the liquid, the surface energy of the solid, and the roughness of the solid surface. Other factors include temperature, pressure, and the presence of impurities on the surface.
4. Why is the contact angle important in science?
The contact angle is important in science because it can provide information about the wetting behavior of a liquid on a solid surface. It can also help determine the surface energy of a solid, which is important in various applications such as coating and adhesion.
5. How does the contact angle affect the spreading of a liquid on a solid surface?
The contact angle determines the degree of wetting of a liquid on a solid surface. A higher contact angle indicates less wetting and a more spherical shape of the liquid drop, while a lower contact angle indicates better wetting and a flatter shape of the liquid drop. The contact angle can also affect the rate of spreading of the liquid on the surface.
  • Classical Physics
  • Classical Physics
  • Mechanics
  • Mechanics
  • Other Physics Topics
