Thread Closed
Measuring rate of reaction via rate of temperature change
Share Thread Thread Tools
Mar15-05, 03:48 PM   #1
In a chemical investigation I'm currently undertaking as part of a chemistry course I'm am studying I'm recording how the temperature changes in several reactions and using the rate of temperature change as a measure of the rate of reaction. I believe this is a valid way to do it as you generally measure rate of reaction as the change in the concentration of some reactant or product with respect to time and I figured that as every reaction has a constant delta H per mole value (change in enthalpy per mole) and the rise in temperature of a substance is directly related to energy transferred to it, that the rate of change of the concentration of a given reactant with respect to time is directly proportional to the rate of change of temperate with respect to time.
Now after doing many different runs of several reactions and recording how the temperature changes in each one and then plotting the initial rate of temperature change (i.e. the gradient of a tangent to the temperature-time graph at the beginning of a reaction) against the initial concentration of a reactant (the initial concentration of the other reactants was kept constant) it appears that measuring the rate of reaction via the rate of temperature range with respect to time appears to work. However I'm also getting quite a few anomalous results (i.e. I need to remove them from the graph so it looks correct) and while plotting the rate of temperature change with respect to time against the concentration of a reactant gives me a pretty nice straight line (which is what I was expecting), the line doesn't intercept the y-axis when the rate of temperature change is 0 (i.e. the line of best fit drawn predicts that the reaction will still occur when the concentration of one of the reactants is 0), it intercepts at something like 1 and given that the range of the rates of the temperature changes I'm measuring is between 1 and 2 this is quite a significant error.
So my question is, can you measure the rate of a reaction by using the rate of temperature change? My results could suggest that you can but then again there appears to be a lot of error and the apparent connection between reaction rate and rate of temperature change could be mere coincidence.
PhysOrg.com
PhysOrg
chemistry news on PhysOrg.com
>> Explainer: What are chemical weapons?
>> Scientists develop advanced biological computer
>> Biofilms move electrons long distances across two distinct layers, even under starving conditions
Mar15-05, 05:33 PM   #2
Admin
Problems with this approach:
heat loses (speed proportional to temperature difference between sample and surroundings)
changes of specific heat with temperature
kinetics changes with the temperature
Still I feel for some systems it can work.
Best,
Borek
http://www.chembuddy.com
Chemical calculators for labs and education
BATE - pH calculations, titration curves, hydrolisis
Mar16-05, 04:37 AM   #3
Well seeing as I'm measuring the initial rate of temperature change (i.e. the rate an infinitesimal amount of time after the beginning of the reaction) things like specific heat should still have the same value as before the reaction. Though of course in practice I can't just work out the rate of temperature change an infinitesimal time after the beginning of the reaction so errors will be present. Luckily I get marked on how I write up the investigation and not if it was sucessful or not
Thanks for the help.
Mar16-05, 08:38 AM   #4
GCT
Recognitions:
Homework Helper Homework Help
In any case I would imagine that measuring the rate of temperature change would actually be more tedious than measuring the rate of change; it'll take longer, more room for error, and the set-up of the experiment will be more complex. Also, note that not all reactions are associated with a large temperature change, at times you'll need to rely on other qualitative measures, such as the change in color.
As for the validity of such measures...
note that rate does not always correspond to thermodynamic properties such as enthalpy change. At times there somewhat independent, unrelated to each other. Rate is proportional to activation energy, while enthalpy's related to the difference between the initial and final enthalpy states. My guess is that the relationship between initial rate of temperature change and the rate of reaction at a specific temperature will be correlational at most. The temperature change also depends a lot on other factors such as the specific heat of water, and thus you'll have a lot of limitations; all in all the rate of temperature change is not controlled, it has a lot of randomness associated with it.
So you've got some complications, you don't want to work with complications.
Thread Closed
Thread Tools
Similar Threads for: Measuring rate of reaction via rate of temperature change
Thread Forum Replies
Help: Zn and HCI reaction rate. Biology, Chemistry & Other Homework 2
Rate of reaction Biology, Chemistry & Other Homework 4
Reaction of Mg with acids (molat enthalpy and rate of reaction) Biology, Chemistry & Other Homework 1
immediate help rate of reaction Biology, Chemistry & Other Homework 2
Related Rate -finding the Rate of Change of an Angle Calculus & Beyond Homework 5
