Automation Systems: Machines for Solar Cells, LCDs, Batteries, Fuel Cells & PCBs
In summary, the conversation discusses the topic of automation systems and machines used in the production of various products such as solar cells, display screens, lithium ion batteries, fuel cells, and printed circuit boards. The speaker is seeking information and resources related to this subject, including video links, text resources, and information on controllers, communication technology, motion control, electronic circuits, and research being done in university labs. Some key points mentioned include the requirements for controllers, the potential advantages of connecting automation systems and machines to the internet, the use of different communication technologies, the predominance of simple DC circuits in these systems, and the function of drivers in controlling hardware.
iii
48
I am interesting to know about the automation systems (production line) and the machines that manufactures these products: solar cells, thin-film solar modules, display screens like: Liquid Crystal Display (LCD), touch panel and plasma, thin film rechargeable lithium ion batteries, lithium ion batteries for electric car, fuel cells and printed circuit boards (PCB).
Some video links that are related to these issues:
Fuel Cell Manufacturing Plant
FlexPicker Robots
If you know about links videos or texts about automation systems or machines that produce these products, I will glad if you can write them in this thread.
I search any connections that can be between machines and automation systems like there are in the video, or that produce the products that I mention above, and several engineering issues.
I have several questions that are related to the control and electronics circuits of automation systems and machines. If you know any link that is related to these subjects so I will glad if you can write them in this thread.
1. I know that they use controllers like in this link:
http://www.boschrexroth-us.com/coun.../sub_websites/brus_dcc/products/pac/index.jsp
1.A. What functions \ requirements the controllers that can be used for applications likes these automation systems and machines need to have?
1.B. I see that the controllers have option to connect to the internet. What can be the applications \ advantages these automation systems and machines can use the internet? 1.C. What communication technology can be use between the different kinds of the controllers in these automation systems and machines?
2.A. I know that there are some standards in motion control hardware, I want to know what are these standard? And how is the organization that is responsible for these standards?
2.B. I search after information and links that have projects that involve control motion for leaser cutting
2.C. What are the control motions that maybe can be use in these automation system and machines?
3.A. What kinds of electronic circuits these automation systems and machines can have? Are these circuit are analogue electronics circuits or digital electronics circuits or both? And why?
3.B. Are these automation systems and machines have power electronics like switches converters? And why these automation systems and machines have or don't have these technologies?
3.C. What is driver? What the drivers do?
4. I am interesting to read links about researches that are doing in the universities labs about the control of these automation systems and machines.​
I'll take a crack at some of your questions.
1.A. Some of the more important requirements and functions that these sorts of controllers need to have are things like data rate for both input and output, loop rate for safety, watchdogs, control of jitter. Perhaps one of the most important things to realize is that in a safety-critical system, you cannot have single points of failure. That means you cannot rely on your controller software alone. I did a real-time system once where we installed processor-independent series relays, each tied to a critical sensor, so that if any of those sensors went to an unsafe range, we could not deliver power to our electrolyzer.
1.B. You could have remote control and monitoring, which could be nice. But, security definitely becomes a problem at that point.
1.C. As for communication buses, you can use Ethernet (my favorite), or you could use EtherCAT for deterministic Ethernet, CAN bus, and loads of others.
3.A. For the automation I did, it was definitely mostly relatively simple DC circuits for sensors and actuators. The most complicated circuit I designed used three relays to control a pump that depended on two level switches. I had to use digital logic to design that circuit.
3.B. Power electronics and control are not usually sold in the same platform. You can certainly control power electronics from an automation system, but you'll almost certainly not be able to buy them in the same package, unless you buy some sort of integrated package (like an Outback power management system). If I had to guess, I would say that the control people probably prefer to keep their stuff separate for market reasons.
3.C. A driver is a piece of software that directly controls hardware. Let's say you have a tunable laser source, and you want to control it. You have an RS-232 communciation channel, and you have a detailed programming manual for the laser source. You will write a driver, so that you have a unified API for access to the functions of the laser source, and your code will look much better as a result.
Related to Automation Systems: Machines for Solar Cells, LCDs, Batteries, Fuel Cells & PCBs
1. How do automation systems work?
Automation systems use a combination of hardware and software components to control and monitor the operation of machines. This can include sensors, actuators, controllers, and programming languages to automate tasks and processes.
2. What are the advantages of using automation systems?
There are several advantages to using automation systems in manufacturing processes. These systems can increase productivity, improve accuracy and precision, reduce human error, and reduce labor costs. They also allow for continuous operation and can increase safety by removing humans from potentially dangerous tasks.
3. Can automation systems be customized for specific industries?
Yes, automation systems can be customized and tailored to fit the needs of specific industries. Different industries may have unique processes and requirements, and automation systems can be designed and programmed accordingly to optimize efficiency and effectiveness.
4. How do automation systems contribute to sustainability?
Automation systems can contribute to sustainability in several ways. By increasing efficiency and reducing waste, they can help conserve resources and reduce the environmental impact of manufacturing processes. Additionally, automation systems can be programmed to monitor and adjust energy usage, further reducing the carbon footprint of production.
5. What are some potential challenges of implementing automation systems?
Some potential challenges of implementing automation systems include the initial cost of installation and ongoing maintenance. Additionally, there may be a learning curve for employees who are used to manual processes, and there may be resistance to change. It is also important to ensure that the automation systems are properly programmed and integrated with existing machines and processes to avoid any disruptions or malfunctions.
9K
  • Mechanical Engineering
  • Electrical Engineering
  • General Engineering
