Objects floating in Ferrofluid
In summary, the conversation discusses the potential applications of ferrofluid and its properties compared to water and oil. The idea of using electromagnets to levitate objects in the ferrofluid is proposed. The speaker also mentions the possibility of using a clear plastic container with a hole in the bottom to manipulate the movement of the object in the fluid.
MrSponge
Hi, I've been thinking about ferroufluid and its application and whether anybody would be able to answer my questions.
Is it denser or lighter than water. I know oil floats but it has iron in it.
Surface tension of it. Reason I am asking about the surface tension is that I was wondering, if i managed to find an object that would float in the ferrofluid by being less dense and buoyant. And that I managed to suspend it in mid air using electromagnets( coils wrapping around it, and i placed this less dense object under neath the ferrofluid or in the side, would it float to the top.
An example of this eqquipment would be a clear plastic container (size of a mug) with ferrofluid inside; with coils of wire hooked up to a battery, wrapped around the container. This container would have a closable hole in the bottom to place the object in. I believe when the coil is powered that the ferrofluid would hover. I would then open the hole in the bottom, push the object in and close the hole, then deactivating the coil, causing the object to float to the top.
Thanks for reading. and appologies for any grammar mistakes.
Depends - you can make a ferro-fluid with a wide range of materials and solid loadings. Densities usually run 0.81 to 3.4 g/cm^3. In the presence of a magnetic field effective densities as high as 20 g./cm^3 can be achieved.
While magnetized, I'd imagine objects would be described as "bouncing off" most commercial ferro-fluids rather than "floating" in it.
Is the idea that you levitate the fluid, leaving a gap under it, a hollow ball falls into the gap, you drop the fluid onto the ball, the ball floats to the surface, where is pops off to repeat the cycle?
1. How does ferrofluid work?
Ferrofluid is a liquid that contains tiny magnetic particles, usually made of iron or iron oxide. When a magnetic field is applied, the particles align and create spiky structures that can be seen on the surface of the liquid. This is known as the "magnetic field pattern" and it allows the liquid to form unique shapes and patterns.
2. Why do some objects float in ferrofluid?
Objects float in ferrofluid because of the magnetic force created by the magnetic field. The particles in the ferrofluid are attracted to the magnetic field and are pushed away from areas with higher magnetic intensity. This creates a "magnetic cushion" that allows objects to appear to float on the surface of the ferrofluid.
3. Can any object float in ferrofluid?
No, not all objects can float in ferrofluid. The object needs to have a strong enough magnetic field to interact with the ferrofluid. Objects made of iron, nickel, or other ferromagnetic materials are able to float in ferrofluid.
4. Is ferrofluid safe to touch?
Ferrofluid is generally considered safe to touch, but it is important to handle it with caution. The particles in ferrofluid are very small and can easily stain surfaces and clothing. It is also important to avoid ingesting ferrofluid as it may contain harmful chemicals. It is recommended to always wash your hands after handling ferrofluid.
5. Can ferrofluid be used for practical applications?
Yes, ferrofluid has many practical applications. It is commonly used in speakers and computer hard drives to help with cooling and lubrication. It is also used in medical applications, such as drug delivery and imaging techniques. Additionally, artists and designers often use ferrofluid to create unique and interactive sculptures and displays.
  • Classical Physics
  • Mechanical Engineering
10K
  • General Engineering
12K
