Does Urine Absorb Atoms from the Air and Create a Vacuum in a Closed Container?
  • Thread starter Thread starter paldin
    Atmosphere
The discussion centers on the phenomenon of urine creating a vacuum in a closed plastic bottle over time. Users speculate that this vacuum formation occurs due to temperature changes and the contraction of air and liquid, rather than any chemical reactions. One participant suggests conducting experiments with warm water to compare results and determine if urine has unique properties that contribute to vacuum formation. The consensus indicates that temperature fluctuations and the physical properties of liquids are the primary factors at play.
  • Understanding of basic thermodynamics, particularly gas laws.
  • Familiarity with the properties of liquids and their behavior under temperature changes.
  • Knowledge of vacuum formation principles in closed systems.
  • Basic experimental design for comparative analysis.
  • Research the principles of gas laws, specifically Boyle's Law and Charles's Law.
  • Investigate the physical properties of urine compared to water, focusing on density and composition.
  • Conduct experiments measuring vacuum levels in various liquids at different temperatures.
  • Explore the concept of atmospheric absorption in liquids and its implications.
This discussion is beneficial for scientists, chemistry enthusiasts, and anyone interested in the physical properties of liquids and vacuum formation in closed systems.
paldin
I have been urinating into a plastic bottle lately (I will not elaborate why), and have been finding the bottle to hold a vacuum the following morning. What I find strange is that even without temperature fluctuations, my bottle produces a vacuum after several hours of being left alone. It is in an otherwise dark and stable place.
Does urine absorb atoms from the air or otherwise convert to a composition that is a lesser volume?
Chemistry news on Phys.org
You said this happens "even without temperature fluctuations". Are you just referring to the ambient temperature? I would imagine if you cap the bottle immediately after filling it, the liquid and air trapped in the bottle would be warmer than the ambient temperature. After cooling, it would contract. Don't think there's any chemistry happening here. I would try the same thing with the same approximate volume of warm water and see what you get.
I use a 1 gallon container and have experimented with the volume before emptying it. When I introduce urine to the container in the hottest part of the day and find a vacuum the next morning when it is significantly colder, I am not surprised. It is when I introduce urine to a moderately full container during the coldest part of the day and still find a vacuum in the warmest part of the day, that has me astonished.
Unless my ≈98° liquid cools so much as to condense the contents of a mostly full 1 gallon container in an ambient temperature ≈90°, I suspect something chemical is occurring. I suppose I should calculate the volume and compare with STP and gas laws, but if urine is known to absorb atmosphere, then I could save myself that effort.
For the sake of argument, I'll warm some water (close to my body temp) and compare the difference. It may turn out to seem like a stronger vacuum than is actually present.
  • · Replies 21 ·
  • · Replies 19 ·
