Proving Basic Exponent Properties for a Group
middleCmusic
When proving that x^m x^n = x^{m+n} and that (x^m)^n = x^{mn} for all elements x in a group, it's easy enough to show that they hold for all m \in \mathbb{Z} and for all n \in \mathbb{N} using induction on n. The case n = 0 is also very easy. But how does one prove this for n \in \mathbb{Z}^{-}?
I tried to do it by using the fact that n = - \nu for some \nu \in \mathbb{N}, but this didn't get me anywhere. Do you have to do induction on the negative integers separately? I'm sure there's a simple answer to this question that I'm just not seeing.
Note that I'm working with the standard recursive definition of exponents, and the definition x^{-n} = (x^{-1})^n.
Update: I think I figured it out. I'd still appreciate a simpler way, if anyone has one.
For a negative integer n, set n = - \nu as before.
Then
<br /> \begin{align}<br /> x^m x^n <br /> &amp;= x^m x^{- \nu} \\<br /> &amp;= x^m (x^{-1})^{\nu} \\<br /> &amp;= ((x^{-1})^{-1})^m (x^{-1})^{\nu} \tag*{since $x = (x^{-1})^{-1}$} \\<br /> &amp;= (x^{-1})^{-m} (x^{-1})^{\nu} \tag*{by the definition of negative exponents} \\<br /> &amp;= (x^{-1})^{-m+\nu} \tag*{by the rule for positive exponents}\\<br /> &amp;= (x^{-1})^{-(m+ (-\nu))}\\<br /> &amp;= (x^{-1})^{-(m+n)} \\<br /> &amp;= ((x^{-1})^{-1})^{m+n} \\<br /> &amp;= x^{m+n} \tag*{since $x = (x^{-1})^{-1}$}<br /> \end{align}<br />
If you liked induction for positive n you can do induction for negative n also. Show if it holds for n, then it holds for n-1 as well
Thread 'Derivation of equations of stress tensor transformation'
Hello ! I derived equations of stress tensor 2D transformation. Some details: I have plane ABCD in two cases (see top on the pic) and I know tensor components for case 1 only. Only plane ABCD rotate in two cases (top of the picture) but not coordinate system. Coordinate system rotates only on the bottom of picture. I want to obtain expression that connects tensor for case 1 and tensor for case 2. My attempt: Are these equations correct? Is there more easier expression for stress tensor...
