LINEAR ALGEBRA: image of vectors through other basis
Felafel
In ##E^3##, given the orthonormal basis B, made of the following vectors ## v_1=\frac{1}{\sqrt{2}}(1,1,0); v_2=\frac{1}{\sqrt{2}}(1,-1,0); v_3=(0,0,1)##
and the endomorphism ##\phi : E^3 \to E^3## such that ##M^{B,B}_{\phi}##=A where
(1 0 0)
(0 2 0) = A
(0 0 0)
find:
##\phi(e_1), \phi(e_2), \phi(e_3)## written with respect to the canonical basis
(where e1, e2, e3 are vector of the canonical basis ##\mathcal{E}##)
here is what I thought, but having no solutions i don't know if it is correct:
I write the vectors of the canonical basis as combination of the vectors of B, also obtaining the ##M^{B,\mathcal{E}}##:
(1,0,0)=##a_{11} \cdot \frac{1}{\sqrt{2}}(1,1,0)+ a_{21} \cdot \frac{1}{\sqrt{2}}(1,-1,0)+ a_{31} \cdot (0,0,1)##
(0,1,0)=##a_{12} \cdot \frac{1}{\sqrt{2}}(1,1,0)+ a_{22} \cdot \frac{1}{\sqrt{2}}(1,-1,0)+ a_{32} \cdot (0,0,1)##
(0,0,1)=##a_{13} \cdot \frac{1}{\sqrt{2}}(1,1,0)+ a_{23} \cdot \frac{1}{\sqrt{2}}(1,-1,0)+ a_{33} \cdot (0,0,1)##
getting:
(##\frac{\sqrt{2}}{2}## ##\frac{\sqrt{2}}{2}## 0)
(##\frac{\sqrt{2}}{2}## -##\frac{\sqrt{2}}{2}## 0)= ##M^{B, \mathcal{E}}##
( 0 0 1)
so ##\phi(e_1), \phi(e_2), \phi(e_3)## are the columns of this matrix.
Is it correct?
thank you in advance :)
I haven't thought it all through, but it doesn't look correct to me. I don't see why those columns would contain the ##\mathcal E##-components of the ##\phi(e_i)##. Do you have an argument for it? Also, I think I have calculated ##\phi(e_3)##, and my result is different from yours.
I think the strategy here should be to start with
$$\phi(e_i)=\phi\left( \sum_j M^{B,\mathcal E}_{ji} v_j\right) =\sum_j M^{B,\mathcal E}_{ji}\phi(v_i).$$ Now you just have to compute the ##\phi(v_i)##. (Did I understand your definition of ##M^{B,\mathcal E}## correctly?)
i don't think i have understood what you mean :(. could you please do an example of the calculation you have done by using a vector?
I don't want to give away too much information. We only give hints here, not complete solutions. But I can of course explain what I did there. I just rewrote ##e_i## as a linear combination of the ##v_i## and then I used that ##\phi## is linear.
The ##\phi(v_i)## are easy to calculate, since you've been given the matrix representation of ##\phi## in the ##\{v_i\}## basis.
thank you :) solved it!
Prove $$\int\limits_0^{\sqrt2/4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx = \frac{\pi^2}{8}.$$ Let $$I = \int\limits_0^{\sqrt 2 / 4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx. \tag{1}$$ The representation integral of ##\arcsin## is $$\arcsin u = \int\limits_{0}^{1} \frac{\mathrm dt}{\sqrt{1-t^2}}, \qquad 0 \leqslant u \leqslant 1.$$ Plugging identity above into ##(1)## with ##u...
