Mathematical Link between Kinetic Force & Electro-Magnet's charge.
The discussion centers on the mathematical relationship between kinetic force applied to two repelling electro-magnets and the resulting effects on their magnetic fields. The original poster seeks clarity on whether mechanical force influences the magnetic fields in measurable electrical terms, such as amperage and voltage. Participants clarify that magnetic charge does not exist, and the focus should be on electric charges and their interactions. The conversation emphasizes the need for a better understanding of how mechanical force impacts the magnetic field strength and its electrical implications. The inquiry remains open for further exploration of these concepts.
Kin Ryu
Greetings!
This is my first post and I am hopefully doing it in the right section of the site.
Onto the topic:
I am searching for the mathematical link between the kinetic force applied on two electro-magnets being forced against each other (assume repelling charges) and the effect that it would have on the magnet's charge.
Either I am the first one to search such information or my google-fu failed Me.
Thank You.
Is something wrong with the way I formulated the question or does no one have a clue ?
Kin Ryu said:
Greetings!
Onto the topic:
Thank You.
Welcome to the PF.
There is no such thing as magnetic charge. Were you asking about electric charges as psparky has posted about?
Ah. Must be a translation mistake from my part.
Let Me try to better illustrate:
When You have an electro-magnet the current (watts) You hook it up to will affect the power of the magnetic field.
Two magnetic field of same polarities will repel each other.
However if You mecanically force them too close to each other; will it affect the magnetic field(s) in a way that will be measured electrically ? (Affecting the Amp/Volts/etc)
And if that is true what is the link between the amount of force needed to push them against each other and the changes in the magnetic field ?
Hi all I have some confusion about piezoelectrical sensors combination. If i have three acoustic piezoelectrical sensors (with same receive sensitivity in dB ref V/1uPa) placed at specific distance, these sensors receive acoustic signal from a sound source placed at far field distance (Plane Wave) and from broadside. I receive output of these sensors through individual preamplifiers, add them through hardware like summer circuit adder or in software after digitization and in this way got an...
I have recently moved into a new (rather ancient) house and had a few trips of my Residual Current breaker. I dug out my old Socket tester which tell me the three pins are correct. But then the Red warning light tells me my socket(s) fail the loop test. I never had this before but my last house had an overhead supply with no Earth from the company. The tester said "get this checked" and the man said the (high but not ridiculous) earth resistance was acceptable. I stuck a new copper earth...
Thread 'Beauty of old electrical and measuring things, etc.'
Even as a kid, I saw beauty in old devices. That made me want to understand how they worked. I had lots of old things that I keep and now reviving. Old things need to work to see the beauty. Here's what I've done so far. Two views of the gadgets shelves and my small work space: Here's a close up look at the meters, gauges and other measuring things: This is what I think of as surface-mount electrical components and wiring. The components are very old and shows how...
