Can linear algebra used to deal with non linear systems?
dexterdev
Hi all,
Can linear algebra used to deal with non linear systems? and why linear algebra is 'linear'? :(
-Devanand T
"Linear" in "Linear Algebra" means "closed under addition". In physics a "linear system" is one that satisfies the superposition principle, which is just the physics way of saying closed under addition. This means that if S_1 and S_2 are two possible states of the system (i.e. two possible solutions to the equations of motion), then S_1 + S_2 is also a possible state of the system (i.e. it also solves the equations of motion). The same word, "linear", is also used to describe the equations of motion in this case; one says that the equations of motion are linear if their solutions satisfy this superposition principle. This use of the word simply generalizes the fact that if you add two points on a line, you end up with a point on the same line.
Linear techniques (e.g. Fourier transformation, perturbation theory, etc.) can be used to approximate the behavior of non-linear systems over sufficiently brief time periods, but most non-linear systems can only be "solved" numerically and display complicated chaotic behavior.
Likes 1 person
linear algebra is linear because it deals with functions such that
f(a*x+b*y)=a*f(x)+b*f(y)
Many nonlinear systems have linear or approximately linear parts so linear algebra is still useful.
Likes 1 person
Thankyou guys...you people cleared my doubt
A good deal of biomath is linearising about stationary points and considering their stability, which helps give a qualitative picture of the overall behaviour.
Thread 'Derivation of equations of stress tensor transformation'
Hello ! I derived equations of stress tensor 2D transformation. Some details: I have plane ABCD in two cases (see top on the pic) and I know tensor components for case 1 only. Only plane ABCD rotate in two cases (top of the picture) but not coordinate system. Coordinate system rotates only on the bottom of picture. I want to obtain expression that connects tensor for case 1 and tensor for case 2. My attempt: Are these equations correct? Is there more easier expression for stress tensor...
