Design of Shaft Diameter for a rotating Drum
The discussion focuses on designing a shaft diameter for a hollow rotating drum used in wastewater purification, which measures 1.77 meters in diameter and 2.5 meters in length, weighing approximately 1555 kg. Key considerations include ensuring the shaft can handle the required torque, prevent sagging, and avoid fatigue failure during operation at 2.7 RPM with a peripheral velocity of 15 m/min. Suggestions include using a tubular shaft design for strength, with solid stub axles at the support bearings. Additionally, an alternative approach of using stub axles at both ends with an indirect drive system is proposed to simplify gearing and accommodate the drum's submerged position. Proper calculations and design adjustments are crucial for effective operation and longevity of the equipment.
amitc21
Hi All,
I am designing a hollow rotating drum equipment which will be filled with specialized media for wastewater purification. I need help to design the shaft diameter for the entire assembly. The Drum will be hollow with a diameter of 1.77 meter and length of 2.5 filled with some kind of material in it. It will be submerged in the liquid at 50% level and will be rotating at 2.7 RPM with peripheral velocity of 15 m/min. The total weight of the drum would be round 1555 kgs. The length of shaft will be 5 meter and mounted with bearing on one end and drive unit on other end. Kindly let me know what can be the shaft diameter and how can We calculate it?
You have not specified if the shaft is horizontal.
You have not specified the torque required to rotate the drum and contents.
The shaft must be of sufficient diameter that it:
1. Is able to transfer the torque required to start and turn the drum.
2. Does not sag and misalign the support or drive bearing.
3. Does not suffer fatigue failure due to continuous reversal of load during rotation.
In that situation I would consider using a tube for the full length shaft. Only at the support bearings need the diameter be reduced to a solid stub axle.
Why must there be a long single shaft. With a drum of that size it might be better to fit a stub axle at each end of the drum and employ an indirect drive with a belt to the surface of the drum. That reduces the gearing needed on the drive unit. Being half submerged has implications to the location of the drive.
Thread 'Turbocharging carbureted petrol 2 stroke engines'
Hi everyone, online I ve seen some images about 2 stroke carbureted turbo (motorcycle derivation engine). Now.. In the past in this forum some members spoke about turbocharging 2 stroke but not in sufficient detail. The intake and the exhaust are open at the same time and there are no valves like a 4 stroke. But if you search online you can find carbureted 2stroke turbo sled or the Am6 turbo. The question is: Is really possible turbocharge a 2 stroke carburated(NOT EFI)petrol engine and...
I need some assistance with calculating hp requirements for moving a load. - The 4000lb load is resting on ball bearing rails so friction is effectively zero and will be covered by my added power contingencies. Load: 4000lbs Distance to travel: 10 meters. Time to Travel: 7.5 seconds Need to accelerate the load from a stop to a nominal speed then decelerate coming to a stop. My power delivery method will be a gearmotor driving a gear rack. - I suspect the pinion gear to be about 3-4in in...
