Solve 3-D Geometry Problem: Find Intersection Line of Bisector Planes
  • Thread starter Thread starter Saitama
    Geometry
The discussion revolves around finding the line of intersection of bisector planes for a triangle formed by the intersection of the plane ax+by+cz=1 with the coordinate axes. Participants clarify that the task does not require finding the bisector planes themselves but rather two points on the intersection line, with the origin identified as one such point. The coordinates of the triangle's vertices A, B, and C are provided, and the incenter is suggested as a potential second point. A formula for the incenter in two dimensions is mentioned, with an attempt to extend it to three dimensions. Overall, the focus remains on understanding the geometry of the problem and finding the necessary points for the intersection line.
Saitama
The planes ax+by+cz=1 meets the axes OX, OY, OZ in A,B,C. A plane through the x-axis bisects the angle A of the triangle ABC. Similarly, planes through the other two axes bisect the angles B and C. Find the equation of the line of intersection of these planes.
Its been quite some time I have done any problems on 3-D geometry. I can find the points where the given plane intersect the axes but how do I find the bisector planes? I need a few hints to begin with.
Any help is appreciated. Thanks!
You don't need to find the planes, all you need is the line of intersection. All you need is two points on that line. The origin is one point on that line, can you find another point?
I myself don't know what the formula will be, it's a strange question.
The following are the coordinates of A,B and C:
##A(1/a,0,0)##, ##B(0,1/b,0)## and ##C(0,0,1/c)##
Since the planes bisect the angles, I guess the other point would be the incentre of triangle ABC. Correct? How did you find that origin is a point satisfying the line.
The given answer is:
$$\frac{x}{\sqrt{b^2+c^2}}=\frac{y}{\sqrt{a^2+c^2}}=\frac{z}{\sqrt{b^2+a^2}}$$
Is this what you get?
I didn't get an answer, I knew the problem would reduce to finding the incenter, which I didn't try to find. I want you to figure out why the origin is on that intersection, keep thinking about that, draw a picture if necessary.
I don't know how I would find the incenter. I would try to solve it in two dimensions first. There may be no easy way to answer it.
Likes 1 person
I think origin is obvious because the bisector planes pass through the axes. :-p
There is a formula I have used before for finding the incentre in two dimensions. I tried to extend it to three dimensions and it seems to work. The formula can be found here:
http://mathworld.wolfram.com/Incenter.html
Thank you verty! :)
I tried to combine those 2 formulas but it didn't work. I tried using another case where there are 2 red balls and 2 blue balls only so when combining the formula I got ##\frac{(4-1)!}{2!2!}=\frac{3}{2}## which does not make sense. Is there any formula to calculate cyclic permutation of identical objects or I have to do it by listing all the possibilities? Thanks
Essentially I just have this problem that I'm stuck on, on a sheet about complex numbers: Show that, for ##|r|<1,## $$1+r\cos(x)+r^2\cos(2x)+r^3\cos(3x)...=\frac{1-r\cos(x)}{1-2r\cos(x)+r^2}$$ My first thought was to express it as a geometric series, where the real part of the sum of the series would be the series you see above: $$1+re^{ix}+r^2e^{2ix}+r^3e^{3ix}...$$ The sum of this series is just: $$\frac{(re^{ix})^n-1}{re^{ix} - 1}$$ I'm having some trouble trying to figure out what to...
