Proving Inequality using Arithmetic and Order Axioms
  • Thread starter Thread starter synkk
    Inequality Proof
The discussion revolves around proving the inequality x.x ≤ y.y given the conditions 0 ≤ x, 0 ≤ y, and x ≤ y using arithmetic and order axioms. Participants express confusion about how to begin the proof and seek clarification on the specific axioms being used. One user successfully applies the axioms to derive that x.x ≤ y.x and x.y ≤ y.y, leading to a better understanding of the proof. Another user inquires about proving the converse, x.x ≤ y.y implying x ≤ y, and considers a contradiction approach, ultimately suggesting starting with the expression 0 ≤ y² - x² = (y + x)(y - x). The conversation highlights the importance of clearly stating axioms and logical steps in mathematical proofs.
synkk
Using only the axioms of arithmetic and order, show that:
for all x,y satisfy 0≤x, 0≤y and x≤y, then x.x ≤ y.y
I'm really lost on where to start, my attempt so far was this
as 0 <= x and 0 <= y, we have 0 <= xy from axiom (for all x,y,z x<=y and 0<=z, then x.z <=y.z). then we use the same axiom to get y.y >= 0, but not sure where to go from there
There are several versions of the "axioms", so you need to tell us exactly what axioms you are given.
Do you see how your axiom, when applied to the hypothesis that 0≤x, 0≤y and x≤y, gives you both x.x≤y.x and x.y≤y.y?
Do you see where to go from here?
Likes 1 person
Thanks I got it from there.
How would I go about proving it the other way? I.e. if 0 <= x, 0 <= y, x.x <= y.y then x <= y? How would I prove that? I have gotten to (x-y).(x-y) <= 0 but not sure how to actually prove it using the axioms which are:
A1 (x+y)+z = x+(y+z)
A2 x + y = y + x
A3 x + 0 = x for all x
A3 x + (-x) = 0
A5 x.(y.z) = (x.y).z
A6 x.y = y.x
A7 x.1 = x
A8 x.x^(-1) = 1
A9 x.(y+z) = (x.y) +(x.z)
A10 x<=y or y<=x for all x,y
A11 if x<=y and y <=x then x = y
A12 x<=y and y <=z then x<=z
A13 x<=y then x + z <= y + z
A14 x<=y and 0<=z then x.z <=y.z
I think the easiest way to prove this is by contradiction.
If you want to try this, I think it'd be easier to start with ##0\leq y^2-x^2=(y+x)(y-x)##.
I tried to combine those 2 formulas but it didn't work. I tried using another case where there are 2 red balls and 2 blue balls only so when combining the formula I got ##\frac{(4-1)!}{2!2!}=\frac{3}{2}## which does not make sense. Is there any formula to calculate cyclic permutation of identical objects or I have to do it by listing all the possibilities? Thanks
