Internal energy of a substance.
The internal energy of an ideal gas is dependent solely on temperature, meaning that during an isothermal process, the change in internal energy is indeed zero. However, in the case of real gases, there is a slight dependence on volume, which can affect internal energy. When condensing from saturated vapor to saturated liquid isothermally, the situation differs as it involves both vapor and liquid phases, thus the internal energy does change. This distinction is crucial as it highlights the limitations of the ideal gas model in real-world applications. Understanding these nuances is essential for accurate thermodynamic analysis.
shenjie
Hi all, I was taught that internal energy of an ideal gas in depending on the temperature which mean during isothermal process, the change in internal energy is equal to zero. Is this statement true?
How about the change in the internal energy of a substance when it is condensed from saturated vapour to saturated liquid isothermally?
Sincerely thanks to those who help me :)
Yes.
No. During the condensation, it is not an ideal gas. It's part vapor and part liquid.
Likes 1 person
That's true for an ideal gas, but in real gases there's a slight dependence of internal energy on volume, i.e. the partial derivative ##\left(\frac{\partial U}{\partial V}\right)_{T,n}## is not exactly zero. This is related to the Joule-Thomson effect.
Likes 1 person
yeah, for a 'true' ideal gas, the internal energy only depends on the temperature (assuming the number of molecules is constant). I think some people call this 'true' ideal gas a 'perfect' gas.
Thread 'Gauss' law seems to imply instantaneous electric field propagation'
Imagine a charged sphere at the origin connected through an open switch to a vertical grounded wire. We wish to find an expression for the horizontal component of the electric field at a distance ##\mathbf{r}## from the sphere as it discharges. By using the Lorenz gauge condition: $$\nabla \cdot \mathbf{A} + \frac{1}{c^2}\frac{\partial \phi}{\partial t}=0\tag{1}$$ we find the following retarded solutions to the Maxwell equations If we assume that...
Thread 'Griffith, Electrodynamics, 4th Edition, Example 4.8. (First part)'
I am reading the Griffith, Electrodynamics book, 4th edition, Example 4.8 and stuck at some statements. It's little bit confused. > Example 4.8. Suppose the entire region below the plane ##z=0## in Fig. 4.28 is filled with uniform linear dielectric material of susceptibility ##\chi_e##. Calculate the force on a point charge ##q## situated a distance ##d## above the origin. Solution : The surface bound charge on the ##xy## plane is of opposite sign to ##q##, so the force will be...
Dear all, in an encounter of an infamous claim by Gerlich and Tscheuschner that the Greenhouse effect is inconsistent with the 2nd law of thermodynamics I came to a simple thought experiment which I wanted to share with you to check my understanding and brush up my knowledge. The thought experiment I tried to calculate through is as follows. I have a sphere (1) with radius ##r##, acting like a black body at a temperature of exactly ##T_1 = 500 K##. With Stefan-Boltzmann you can calculate...
