Black Hole & Wormhole: Questions Answered
Superposed_Cat
Hi, two questions
A) If a black hole travels into a wormhole would it collapse the wormhole?
B) If a wormhole travels through another wormhole what would happen?
Thanks for any help.
Without a proper theory about wormholes, this is impossible to answer.
Short answer: Generally, yes.
Longer answer: Depends on the mass of the black hole relative to that of the wormhole. It also depends on the so-called equation of state of the exotic matter that sustains the wormhole. However, as a rule of thumb you would expect a black hole, whose mass is very much smaller than that of the wormhole, not to collapse the wormhole. Conversely, if the black hole's mass is very much larger, it would almost certainly collapse the wormhole.
Here's an excerpt from this Wormhole FAQ
What would happen if two mouths of the same wormhole were to collide?
After the collision identical mouths would 1) coalesce, if their masses are positive, or 2) separate, if their masses are negative. Upon coalescing, the wormhole’s shape would be something like the three-dimensional generalization of the surface of an eye screw (Figure 1.2). A traveler could enter the single mouth of the wormhole, travel the length of its interior region, and exit the mouth only to discover that she is back where she started.
Figure 1.2. A wormhole Self Collision. Mouths will likely coalesce.
The FAQ seems to be taken from The Physics of Stargates -- Parallel Universes, Time Travel and the Enigma of Wormhole Physics by Enrico Rodrigo.
Likes 1 person
In this video I can see a person walking around lines of curvature on a sphere with an arrow strapped to his waist. His task is to keep the arrow pointed in the same direction How does he do this ? Does he use a reference point like the stars? (that only move very slowly) If that is how he keeps the arrow pointing in the same direction, is that equivalent to saying that he orients the arrow wrt the 3d space that the sphere is embedded in? So ,although one refers to intrinsic curvature...
ASSUMPTIONS 1. Two identical clocks A and B in the same inertial frame are stationary relative to each other a fixed distance L apart. Time passes at the same rate for both. 2. Both clocks are able to send/receive light signals and to write/read the send/receive times into signals. 3. The speed of light is anisotropic. METHOD 1. At time t[A1] and time t[B1], clock A sends a light signal to clock B. The clock B time is unknown to A. 2. Clock B receives the signal from A at time t[B2] and...
So, to calculate a proper time of a worldline in SR using an inertial frame is quite easy. But I struggled a bit using a "rotating frame metric" and now I'm not sure whether I'll do it right. Couls someone point me in the right direction? "What have you tried?" Well, trying to help truly absolute layppl with some variation of a "Circular Twin Paradox" not using an inertial frame of reference for whatevere reason. I thought it would be a bit of a challenge so I made a derivation or...
