Travelling waves - help with formula
  • Thread starter Thread starter FaraDazed
    Formula Waves
The wave described by the equation y(x,t)=2sin(6t-0.5x) has a frequency of approximately 0.95 Hz, a wavelength of 4π meters, and a velocity of about 11.94 m/s. For the second question, substituting x=2 into the wave equation yields the expression for displacement as 2sin(6t-1). There is some ambiguity in the wording of the question regarding "from the beginning of the wave," but it is generally interpreted to mean from x=0. The calculations for frequency, wavelength, and velocity are confirmed to be correct. Overall, the discussion seeks clarification on the interpretation of the wave's displacement at a specific point.
FaraDazed
A wave has the mathmatical form y(x,t)=2sin(6t-0.5x)
1. What is the waves frequency, wavelength and velocity
2.Write an expression for the displacement of the wave as a function of time at a point 2m from the beginningof the wave.
<br /> k=2\pi \lambda \\<br /> f=\frac{\omega}{2\pi} \\<br /> v=\lambda f <br />
For question 1 I took 6 from the wave equation to be the angular velocity and k to be 0.5 so i did..
<br /> f=\frac{6}{2\pi}=0.95Hz \\<br /> \lambda=\frac{2\pi}{0.5}=4\pi metres \\<br /> v=\lambda f = 4\pi (0.95)=11.94 m/s<br />
For question 2 I am not too sure what the question is asking, if it is 2m from the start do I just plug 2 in for x in the wave equation given? to get 2sin(6t-1)?
Any help appreciated, thanks :)
You work looks good to me. I agree that the second question isn't worded very well. The phrase "from the beginning of the wave" is a little odd. But it seems reasonable to me to assume they mean from x = 0, in which case your expression is correct.
Thread 'A bead-mass oscillatory system problem'
I can't figure out how to find the velocity of the particle at 37 degrees. Basically the bead moves with velocity towards right let's call it v1. The particle moves with some velocity v2. In frame of the bead, the particle is performing circular motion. So v of particle wrt bead would be perpendicular to the string. But how would I find the velocity of particle in ground frame? I tried using vectors to figure it out and the angle is coming out to be extremely long. One equation is by work...
