Why Doesn't an Electron Move When Pushed by Equal and Opposite Forces?
  • Thread starter Miraj Kayastha
  • Tags
    Force
In summary, when pushing an electron towards another electron, we need to give an equal but opposite force in order to overcome the repulsive force and move the electron. This force must be greater than the repulsive force in order to create a change in potential energy. The equal and opposite forces only cancel out when acting on the same object in equal magnitude and opposite direction.
Miraj Kayastha
80
If we want to push an electron towards another electron we give equal but opposite force which means we push the electron with the same amount of force that it is being pushed back.
Shouldn't both the forces cancel out the electron remain stationary?
If you give an equal force to the electron the forces will be neutral so a force greater than the neutral state shall be needed to push
The forces are on two different particles they would only cancel if the two forces acted on the same object in equal magnitude and opposite direction.
No. We're applying a force to electron that is greater than the repulsive force, so the forces on the electron are not balanced and it moves. The "equal and opposite force" is the force the electron exerts on us when we're pushing on it.
"F in the definition of potential energy is the force exerted by the force field, e.g., gravity, spring force, etc. The potential energy U is equal to the work you must do against that force to move an object from the U=0 reference point to the position r. The force you must exert to move it must be equal but oppositely directed, and that is the source of the negative sign. The force exerted by the force field always tends toward lower energy and will act to reduce the potential energy." - Hyperphysics
The above definition tells us that equal and opposite force must be exerted to move an object against a field. How can the object move?
This is not true in general. If you have an equal and opposite force then there will be no acceleration, but that is not required in general.
Also, equal and opposite forces on a single object imply no acceleration, not no movement. It will continue moving with it's initial velocity.
So you mean to say the definition in hyperphysics is wrong?
No, you are misunderstanding the issue. The issue is that all forces - all forces come in equal and opposite pairs. When you push on a box on the floor and it doesn't move due to friction, that isn't two forces, that's four. Two pair:
-You push on the box and it pushes back.
-The box pushes on the floor and the floor pushes back.
See, Newton's 3rd law is talking about force pairs, whereas Newton's second law is talking only about the force applied to the body, not the reaction force applied back.
The definition in hyperphysics isn't talking about Newtons third law.
Yes, specifically the statement that I quoted is wrong and is the one that is the source of your confusion.
Agreed - but the OP is. He just doesn't know it.
"Not true in general" isn't the same as "wrong". I agree that it isn't true in general, but I disagree that it is wrong. What it is is simplified for the sake of explanation. We often get the question here that if potential energy (gravitational, for example) is equal to the force of gravity times distance, how can the object move?
The answer is a limiting case of a force negligibly above the weight. For introductory or practical purposes I don't see it as being important to go into that when one first explains it. If someone asks, fine, but if not, it saves a little time.
In either case, regardless of the force applied, the force that contributes to the potential energy is exactly equal to the weight.
But none of that has anything to do with the original question. The original question was if you push on something and it pushes back with an equal and opposite force, how can it move? That's confusing Newton's 2nd and 3rd laws.
I think it's clear from the context that the question is not about Newton's 3rd law. You push an electron towards another with exactly an equal an opposite force that the other electron is exerting. All forces in question act on the electron. The question doesn't talk about anything pushing back on you.
The point that the OP raises is a subtle point often glossed over in texts, as it is in the Hyperphysics statement quoted.
In order to change the position of a charge q at rest in an electric field, E, it is not enough to give it a force equal to -qE. That just keeps it in the same position. One has to apply a force to that charge that is greater in magnitude than |-qE|. The application of this force gives q some kinetic energy. A change in potential energy comes from a loss of that kinetic energy when the charge returns to rest in a new position.
AM
Andrew Mason said:
In order to move a charge q against an electric field, E, it is not enough to give it a force equal to -qE.
Yes it is.
Or moves it at constant speed.
That is needed to accelerate, not to move.
A.T. said:
Yes it is.
Your point is well taken. However, the OP is dealing with a situation in which a charge is held at a certain position in an electric field. This means that a force of -qE has to be applied to the charge in order to keep it there. The force required to move that charge (to change its position) must be greater than -qE. I have edited my post to make that clear.
AM
1. What is "equal but opposite force"?
"Equal but opposite force" refers to Newton's Third Law of Motion, which states that for every action, there is an equal and opposite reaction. This means that when an object exerts a force on another object, the second object exerts an equal force in the opposite direction on the first object.
2. How does "equal but opposite force" affect motion?
"Equal but opposite force" plays a crucial role in determining the motion of objects. When two forces of equal magnitude act in opposite directions on an object, they cancel each other out and result in a net force of zero. This means that the object will remain at rest or continue moving at a constant velocity.
3. Can "equal but opposite force" be seen in everyday life?
Yes, "equal but opposite force" can be observed in many everyday situations. For example, when we walk, our foot exerts a force on the ground, and the ground exerts an equal and opposite force on our foot, propelling us forward. Another example is when we push a door open, the door exerts an equal and opposite force on us, allowing us to enter the room.
4. How is "equal but opposite force" related to momentum?
According to Newton's Third Law, the forces of action and reaction are equal and opposite, but they act on different objects. This means that the momentum of the two objects will be equal and opposite as well. For example, when a ball is kicked, the force of the kick on the ball is equal and opposite to the force of the ball on the foot, but the momentum of the ball will be in the opposite direction of the momentum of the foot.
5. Are there any exceptions to "equal but opposite force"?
While Newton's Third Law is a fundamental principle of physics, there can be exceptions to "equal but opposite force" in certain situations. For example, in a rocket, the force of the exhaust gases pushing out of the back of the rocket is greater than the force of gravity pulling the rocket down, resulting in a net force and allowing the rocket to move upwards.
  • Other Physics Topics
  • Classical Physics
  • Classical Physics
