Projectile Motion of a Man Problem
A man throws a rock from a 14.1m high building at a speed of 29.3m/s and an angle of 29.9 degrees. The maximum height reached by the rock is confirmed to be 10.9m, and the velocity just before impact is calculated at 33.7m/s. The initial horizontal distance calculated was 57.4m, but this was deemed incorrect due to not accounting for the total flight time. After including the time to reach maximum height, the correct horizontal distance is recalculated to be 95.25m. The discussion emphasizes the importance of considering both ascent and descent times in projectile motion calculations.
TheRedDevil18
A man stands on the roof of a building of height 14.1m and throws a rock with a velocity of magnitude 29.3m/s at an angle of 29.9 degrees above the horizontal. You can ignore air resistance.
1) Calculate the maximum height above the roof reached by the rock.
2) Calculate the magnitude of the velocity of the rock just before it strikes the ground.
3) Calculate the horizontal distance from the base of the building to the point where the rock strikes the ground.
1) 10.9 m, I know that's right
2) 33.7 m/s, that's also correct
3) 57.4 m, but this answer is wrong, I think
this is how I worked it out
x = Vx*t
= 25.4*2.26 (The vertical time it took to drop from it's max height to the ground)
= 57.4 m
x = Vx*t
= 57.4 m
What about the time it took to rise to the maximum height?
Ok so the time it took to rise to max height was 1.49's so the total flight time will be 2.26+1.49 = 3.75's
So it should be,
x = Vx*t
= 25.4*3.75
= 95.25 m, Correct ?
So it should be,
x = Vx*t
= 25.4*3.75
Good.
Doc Al said:
Good.
Thanks ! :)
