A question about bacterias traveling in\on asteroids.
  • Thread starter Anonymous_1
  • Tags
    Asteroids
In summary, some bacteria can survive in space, but it would have to be contained in an airtight capsule.
Anonymous_1
How long can a bacteria dwell? Can it dwell in space, or would the air be sucked out of it and the cell would be destroyed? Would it have to be incased in an airtight chamber inside an asteroid for it to travel in space? Thanks :bugeye:
Biology news on Phys.org
Even some higher organisms are capable of surviving conditions on the orbit (Tardigrada), so there is no reason to not believe some bacteria could survive too. I would be surprised if they were not tested by NASA and if the results were impossible to google.
Would it have to be contained inside an airtight capsule in the asteroid? Wouldn't the vacuum in space suck the air out of the bacteria? Wouldn't it be hard to find the molecules needed for reproducing inside an airtight capsule inside a rock? Thanks
What you're really asking is, would the cell wall of the bacteria withstand the difference between the internal pressure in the cell and the vacuum of space around it? I believe the answer is yes, depending on the species of bacteria and, probably, the external pressure in the environment it was in prior to being subjected to a vacuum. And once it got past the initial imposition of a vacuum, its continued survival would depend on whether its cell wall is capable of holding in the cell contents indefinitely, whether it can survive extreme cold, how much radiation damage it's subjected to, etc. Its internal processes would probably cease until warmth and external pressure were restored, and then only if the cell wall hadn't ruptured or leaked substantially.
Additionally, some bacteria can make spores which are resistant to temperature extremes, radiation, nutrition deficiencies etc. From memory, spores are basically a, mostly dehydrated, core with some nucleic acids and proteins with several layers of membrane, cell wall and tough peptidoglycan membrane(s) helping to accomplish this resistance to extreme conditions. Googling will bring up some info.
Yes. Aliens build those capsules all the time.
But seriously, bacteria in asteroids don't have to be kept in some sort of a container. It is gravitationally attracted to the asteriod. I'm not sure what you want to know in this thread
cb
(Mentor note -- as you can tell by the italics font in the OP's username, he is no longer with the PF. Not for anything he was asking about in this thread here, BTW.)
1. Can bacteria survive in space and on asteroids?
Yes, bacteria have been shown to survive in the harsh conditions of space and on asteroids. They can enter a dormant state called spores, which can protect them from extreme temperatures, radiation, and lack of nutrients. They can also hitch a ride on debris or other organisms, allowing them to travel through space.
2. How do bacteria travel on asteroids?
Bacteria can travel on asteroids through a process called panspermia. This is when microorganisms are transported from one celestial body to another, either by impact events or by hitching a ride on debris. Bacteria can also be ejected into space through volcanic eruptions or other geological processes.
3. Could bacteria on asteroids be harmful to humans?
It is possible for bacteria on asteroids to be harmful to humans if they were to make contact with us. However, the likelihood of this happening is extremely low, as the conditions on asteroids are not suitable for bacterial growth. Also, our immune systems are capable of fighting off most bacterial infections.
4. What types of bacteria could potentially travel on asteroids?
There are many types of bacteria that could potentially travel on asteroids, including extremophiles that are able to survive in extreme environments, such as outer space. Some examples include Deinococcus radiodurans, which can withstand high levels of radiation, and Thermococcus gammatolerans, which can survive in high temperatures.
5. Is there any evidence of bacteria traveling on asteroids?
There is currently no direct evidence of bacteria traveling on asteroids. However, there have been studies that suggest the possibility of bacterial survival on asteroids, as well as the discovery of organic compounds on meteorites that could potentially support microbial life. Further research and exploration will be needed to gather more evidence.
  • Biology and Medical
  • Astronomy and Astrophysics
