Can we produce a white laser from a visible light spectrum?
The discussion centers on the feasibility of using two prisms to convert a white laser into a visible light spectrum and then back into a laser. The original poster argues that this is theoretically impossible since prisms disperse light rather than converge it. However, some participants suggest that while a laser can produce a broad spectrum, the temporal dispersion caused by the prisms complicates the process. The conversation also touches on ultrafast lasers and the concept of Chirped Pulse Amplification (CPA) as a method to manage dispersion, although the professor's restriction to only using prisms limits the options. Ultimately, the poster plans to experiment in the lab despite the challenges presented.
athrun200
I am doing a final year project, my Prof gave me 2 prism.
He wants me to do so:
A white laser is shot on a prism producing a visible light spectrum, use another prism to converge the spectrum back into a laser.
For me, it is theoretically impossible and I tried to convince him that it doesn't work as prism can only make the light more disperse. But he insisted that by principle of reversibility, there should be a way to convert the spectrum back to a laser.
Is he really correct? I want to disprove his statement but I cannot figure out a concrete proof.
I don't know what to do now.
Science news on Phys.org
You can easily produce white light by combining different colors via a prism. You can't make a laser out of it, as a laser uses stimulated emission to produce a coherent beam of light that consists of a small range of wavelengths, but you definitely make plain white light.
That means even if the original light source is a laser, it will become a plain white light after 2 prisms?
Do you have a white light laser? I think that they all use super-continuum white light generation techniques, like this one: http://www.nktphotonics.com/superk_compact
So let's assume you have a laser with significant bandwidth; the ultrafast lasers I work with have bandwidth of 20-50 nm. For a "white light" laser you would have about 350 nm of bandwidth: 400 nm (deep blue) to 750 nm (deep red). For any of these broad-bandwidth lasers you will also have temporally short pulses: typically less than one picosecond, down to 10 femtoseconds. This is the ultrafast pulsed laser temporal range.
Now send the pulse through a prism: the colors separate (disperse) due to the differing speeds of light through the glass. They will also exit the prisms with different angles, so your pulse will be spread spatially, and temporally: the colors are fanned out spatially, but the blues will have exited first, and the reds last-hence they are also fanned out temporally.
The usual way to use prisms is in pairs: you adjust both members of the pair so that the beams enters/exits at the "angle of minimum deviation". You can actually use your eyes to determine this physical alignment, and after the beam exits the second prism it will be "all travelling" in the same direction again: the dispersion is cancelled.
However, your temporal dispersion is still there.
The fix for this is to be found in the design of the ultrafast CPA laser: CPA=Chirped Pulse Amplification. My thesis advisor was one of the inventors of this method in the late 1980s; see http://www.cap.ca/fr/node/709
Here is a nice picture with explanations: http://en.wikipedia.org/wiki/Prism_compressor
But it is easier to work with gratings; then you don't get non-linear optical interactions within the prisms!
See http://en.wikipedia.org/wiki/Chirped_pulse_amplification
Yes, I have a white light laser. Thanks so much, it's so informative.
In fact, my Prof restricts me to use 2 prisms only, no grating is allowed.
I will give it a try tomorrow in the lab!
I would like to use a pentaprism with some amount of magnification. The pentaprism will be used to reflect a real image at 90 degrees angle but I also want the reflected image to appear larger. The distance between the prism and the real image is about 70cm. The pentaprism has two reflecting sides (surfaces) with mirrored coating and two refracting sides. I understand that one of the four sides needs to be curved (spherical curvature) to achieve the magnification effect. But which of the...
