Rate of change of x wrt sin(x)
In summary, the conversation discusses the possibility of computing the rate of change of x with respect to sin(x), with suggestions to use Excel and different methods such as comparing with dsin^-1(x)/dx and turning the graph of sin(x) on its side. The conversation then delves into the use of the inverse function theorem and the difference between 1/cos(x) and 1/|cos(x)| when differentiating with respect to sin(x). It is concluded that the absolute value drops depending on the domain of the sine function.
Jhenrique
685
Is possible to compute the rate of change of x wrt sin(x)? ##\frac{dx}{d \sin(x)}##
Mathematics news on Phys.org
Have you tried just plotting it in Excel? You will get some 1/0 inflection points that you will need to deal with...
Compare with ##\frac{dsin^{-1}(x)}{dx}##
Or, turn the graph of sin(x) on its side.
Compare to reciprocal dsin(x)/dx. Sin-1(x) is not relevant.
Why isn't it relevant?
If we have dx/d(sinx), why is it not reasonable for me to let sinx = y and therefore have that x = arcsin(y)?
Then I have d(arcsin(y))/y = 1 / sqrt(1-y²)
And thus dx/d(sinx) = 1/sqrt(1-sin²(x)) = 1/sqrt(cos²(x)) = 1/|cos(x)|
Just curious, so where does this break down? This is a very unique question so I'm sure there is an error in my logic. One may note that this comes out to be only slightly different than the reciprocal method (no absolute value). I suspect this is because in assigning these variables in the way I did, I restricted/changed domain?
Due to the inverse function theorem, it is very relevant.
After a quick Google, it looks like I followed this theorem with f(a) = sin(x). So why does f'(b) evaluate to 1/|cos(x)| according to my work rather than 1/cos(x) as the inverse function theorem claims it should?
I mean, hopefully we can agree that the answer to the OP's question is actually 1/cos(x) and not 1/|cos(x)|.
There are two ways to "differentiate x with respect to sin(x)". The first is to use the fact that
[tex]\frac{dx}{dy}= \frac{1}{\frac{dy}{dx}}[/tex].
Here y= sin(x) so dy/dx= cos(x). Then dx/dy= 1/cos(x) is a perfectly good answer.
The other way is to say that if y= sin(x) then [itex]x= sin^{-1}(y)[/itex] so that the derivative of "x with respect to sin(x)" is [itex]dx/dy= d(sin^{-1}(y))/dy= 1/\sqrt{1- y^2}[/itex].
It's not at all difficult to prove that those are the same. If y= sin(x) then [itex]1- y^2= 1- sin^2(x)= cos^2(x)[/itex] so [itex]1/\sqrt{1- y^2}= 1/cos(x)[/itex].
So, I can differentiate any function f(x) wrt another any function g(x).
If df = f'(x) dx and dg = g'(x) dx, thus df/dg = f'/g' ...
Our work is the same, but I don't understand how you conclude that sqrt(cos²(x)) = cos(x). This is |cos(x)|, don't you agree?
Well, the sine function is not invertible, since it's not injective and not surjective. This is of course no problem for the inverse function theorem, since it will take a "local inverse".
You worked with the arcsine, which is indeed a local inverse. But not all local inverses are like the arcsine. That is, if we restrict the sine to ##(-\pi/2,\pi/2)## then the arcsine is an inverse. But guess what? The cosine function is actually positive on that said, so the absolute values drop.
If you apply the inverse function theorem on some other domain, then you can't use the arcsine anymore in that form.
Does that make sense?
Likes 1 person
Yes, thank you.
1. What is the definition of "rate of change of x wrt sin(x)"?
The rate of change of x with respect to sin(x) is the instantaneous change in the value of x with respect to the change in the value of sin(x). In other words, it measures how much x changes for every unit change in sin(x).
2. How is the rate of change of x wrt sin(x) calculated?
The rate of change of x with respect to sin(x) can be calculated using the derivative formula, which is the limit of the change in x over the change in sin(x) as the change in sin(x) approaches 0.
3. What does a positive/negative rate of change of x wrt sin(x) indicate?
A positive rate of change of x with respect to sin(x) indicates that as sin(x) increases, x also increases. This means that the graph of x with respect to sin(x) has a positive slope. On the other hand, a negative rate of change of x with respect to sin(x) indicates that as sin(x) increases, x decreases, and the graph has a negative slope.
4. How is the rate of change of x wrt sin(x) related to the graph of x and sin(x)?
The rate of change of x with respect to sin(x) is related to the slope of the graph of x and sin(x). The slope at any point on the graph is equal to the rate of change of x with respect to sin(x) at that point. This means that the steeper the graph, the higher the rate of change of x with respect to sin(x).
5. Can the rate of change of x wrt sin(x) be negative infinity or undefined?
Yes, the rate of change of x with respect to sin(x) can be negative infinity or undefined. This happens when the graph of x and sin(x) has a vertical tangent, which means that the slope is undefined or infinite at that point. This can occur at points where sin(x) is equal to 0 or 1, since the derivative of sin(x) is undefined at these points.
  • General Math
  • General Math
  • General Math
  • General Math
