Basic kinematics - fox jumping over a wall problem
  • Thread starter Thread starter chococho
    Kinematics Wall
A fox is attempting to jump over a wall, and the problem involves calculating its height when it reaches the wall, given its initial velocity and angle. The initial calculations for vertical and horizontal velocity components were incorrect, as the correct approach involves using trigonometric functions to find these components. The time to reach the wall can be determined using the horizontal distance and horizontal velocity. The vertical displacement can then be calculated using the correct time and accounting for gravitational acceleration. The expected height of the fox when it reaches the wall is 0.7 m, highlighting the importance of accurate calculations in kinematics.
chococho
basic kinematics -- fox jumping over a wall problem
A fox is 3.2 m from a 0.5 m tall wall. If it leaps from the ground towards the wall with an initial velocity of 12.0 m/s at angle of 18.9° above the horizontal, how high off the ground will the fox be when it reaches the wall?
Δx = vxt
Δy = 1/2a2t
First I tried to find Vy by doing "tan 18.9 = y/12"
and got 4.10 m/s.
Then I found the time by doing 3.2 = 12t
and got 0.266 sec.
I have no idea if I'm on the right track.
Then I just plugged in time and acceleration to find Δy and got 0.346 but it's wrong.
The answer is supposed 0.7 m...
Any help?
Δx = vxt
Δy = 1/2a2t
and got 4.10 m/s.
and got 0.266 sec.
Any help?
Welcome to PF chococho!
vy is the component of velocity in the vertical direction so it is just: v0sinθ
vx is the component of velocity in the horizontal direction so it is: v0cosθ
Using vx you can find t. Then use vy, factoring in the acceleration due to gravity, to determine how high the fox goes in the time t.
AM
Second equation you used is missing a term.
Also tan does not give you vy.
You have the initial velocity v = 12ms^{-1} and the angle \theta = 18.9 ° with the horizontal,
find v_x = v \cos \theta , its horizontal component, and v_y = v \sin \theta.Its vertical component. (That's where you were wrong.)
Then find time using the equation Δx =v_x t
Then solve for Δy = \frac{1}{2} at^2
Thank you everyone. Kinematics is the first thing I learned in physics and I have a final coming up so I'm trying to re-learn this stuff... Still struggling :(
Try to practice as many times as you can.
Kinematics is just like maths :smile:
