Dirac's statement about conservation
  • Thread starter Thread starter exmarine
    Conservation
exmarine
In Dirac's book on GRT, he says the following, p. 45: "In curved space the conservation of energy and momentum is only approximate. The error is to be ascribed to the gravitational field working on the matter and having itself some energy and momentum."
Yet when I work my way from the Schwarzschild metric to the geodesic equations, one of them produces the conservation of angular momentum. There is no approximation that I am aware of.
What am I missing? Was Dirac wrong? Can anyone explain? Thanks.
I think he was referring to arbitrary metrics. A general metric without angular symmetry will not conserve angular momentum along the geodesic.
Say instead we were talking about the EM field. Then ##T_{\mu\nu} = T^{\text{charges}}_{\mu\nu} + T^{\text{EM}}_{\mu\nu}## hence ##\nabla^{\mu}T_{\mu\nu} = 0## already takes into account the energy-momentum of the EM field when talking about the local conservation of energy-momentum of the charge distribution interacting with this EM field. It is immediate from this why there comes a difficulty when wanting to take into account the energy-momentum of the gravitational field interacting with a given matter distribution in speaking of the local conservation of energy-momentum because we cannot write down the local energy-density of the gravitational field; ##\nabla^{\mu}T_{\mu\nu} = 0## does not account for this! In fact in GR we can only talk about the energy-momentum of the gravitational field using global quantities (such as the Komar energy/angular momentum, ADM energy-momentum etc.) or pseudo-tensorial quantities (such as the LL pseudo-tensor).
So Dirac's statement is much deeper and much more general than that of an axially symmetric space-time possessing an axial Killing field conserving angular momentum.
There are two different things here:
(1) Conservation of angular momentum for a test particle moving in a fixed background metric.
(2) Conservation of angular momentum for the field theory in general, including the angular momentum contained in the gravitational fields itself.
Dirac is talking about #2.
GR doesn't have general conservation laws for vectors and higher-order tensors. As an alternative to Dirac's explanation, this can be seen from the fact that parallel transport is path dependent in GR. Therefore you can't define any unique way to add up the conserved quantity.
In this video I can see a person walking around lines of curvature on a sphere with an arrow strapped to his waist. His task is to keep the arrow pointed in the same direction How does he do this ? Does he use a reference point like the stars? (that only move very slowly) If that is how he keeps the arrow pointing in the same direction, is that equivalent to saying that he orients the arrow wrt the 3d space that the sphere is embedded in? So ,although one refers to intrinsic curvature...
ASSUMPTIONS 1. Two identical clocks A and B in the same inertial frame are stationary relative to each other a fixed distance L apart. Time passes at the same rate for both. 2. Both clocks are able to send/receive light signals and to write/read the send/receive times into signals. 3. The speed of light is anisotropic. METHOD 1. At time t[A1] and time t[B1], clock A sends a light signal to clock B. The clock B time is unknown to A. 2. Clock B receives the signal from A at time t[B2] and...
So, to calculate a proper time of a worldline in SR using an inertial frame is quite easy. But I struggled a bit using a "rotating frame metric" and now I'm not sure whether I'll do it right. Couls someone point me in the right direction? "What have you tried?" Well, trying to help truly absolute layppl with some variation of a "Circular Twin Paradox" not using an inertial frame of reference for whatevere reason. I thought it would be a bit of a challenge so I made a derivation or...
