Register to reply
Plastic shredder for shredding plastic?
by IanJohnson
Tags: plastic, shredder, shredding
Share this thread:
IanJohnson
#1
Jun19-14, 02:26 PM
P: 1
I am looking into the possibility of making this shredder to shred failed 3D prints, mostly ABS.
https://grabcad.com/library/mini-shredder--1
Here is a printed version, which can't shred plastic-
https://www.youtube.com/watch?v=A4rg--VEXVM
These are expensive to make in steel, but I was wondering if there was a plastic alternative that could at least handle ABS. Acrylic is pretty hard, and I can cut that on my laser cutter. Polycarbonate might work, though I would need to send it somewhere for CNC. What material properties are the most important for maintaining a sharp edge and resisting wear? Hardness? Impact resistance? At the very least it would need to be very stiff so it won't bend when it should shear.
Phys.Org News Partner Engineering news on Phys.org
DIY glove-based tutor indicates muscle-memory potential
Tricorder XPRIZE: 10 teams advance in global competition to develop consumer-focused diagnostic device
Study shows local seismic isolation and damping methods provide optimal protection for essential computing equipment
Lok
#2
Jun20-14, 02:06 PM
P: 462
Hello Ian,
Any plastic is not a good material for this task as all will wear out fast and definitely cannot keep an edge.
To give you an idea: The lowest steel has a tensile strength of 180 N/mm^2 while the best of the plastics is around 70 N/mm^2 (I do mean a solid piece). ABS has 30-40 and Acrylic has around 60-65. It will wear out in a few passes.
For holding an edge you need a hard material of which steel is the cheapest one i can think of.
Seek and purchase something like this in conjunction with some low power tools:
http://www.clasohlson.com/medias/sys...3729818654.jpg
and remember to use a face mask as breathing in plastic powder is detrimental to your lungs.
Register to reply
Related Discussions
Justifying the purchase of a plastic box over plastic bags. Engineering, Comp Sci, & Technology Homework 1
Differences between Pseudo-plastic and Bingham plastic? Materials & Chemical Engineering 1
ABS Plastic Materials & Chemical Engineering 13
Just That Bit of Plastic Please... General Discussion 25
Ink on plastic Chemistry 7
