Basic Diodes/Van de Graaff generator
  • Thread starter Thread starter Steven Ellet
    Generator
The most basic diode is a PN-junction diode, which allows electricity to flow in one direction. However, diodes have a reverse breakdown voltage, meaning they can conduct current in the opposite direction if that voltage is exceeded, which is important for protection against static electricity. Regarding Van de Graaff generators, the polarity of the charge produced depends on the configuration of the rollers and the belt material used. Swapping the positions of the metal and insulated rollers can change the generator's polarity. Understanding these principles is crucial for effectively utilizing diodes and Van de Graaff generators in experiments.
Steven Ellet
What is the name of the most basic diode?
I know that there are quite a few types of diodes, but all I want is one that will force electricity to flow in one direction and do nothing else.
________________________________________________________________
On an unrelated note, how would a Van de Graaff generator that makes a negative charge, vary from one that makes a positive charge, and how would I make one that does positive?
The basic diode is just a PN-junction diode.
They won't do it at voltages created by a Van de Graaff generator. diodes have a 'reverse breakdown' voltage, at which they will freely conduct current in the opposite direction. In fact, diodes are used as protection against static electricity by having them short to ground when faced with voltages higher than the circuit is supposed to see (ie greater than 15 volts).
I thank you for answering one of my questions, however I was not implying that the two would work together, only that I wished for two answers but did not wish to make two post.
The Van de Graaff generator has two rollers for the belt. One is metal, the other is insulated.
I believe it is the position of those rollers, and the belt material that determines polarity.
If you swap the rollers you should change the polarity.
Hi all I have some confusion about piezoelectrical sensors combination. If i have three acoustic piezoelectrical sensors (with same receive sensitivity in dB ref V/1uPa) placed at specific distance, these sensors receive acoustic signal from a sound source placed at far field distance (Plane Wave) and from broadside. I receive output of these sensors through individual preamplifiers, add them through hardware like summer circuit adder or in software after digitization and in this way got an...
I have recently moved into a new (rather ancient) house and had a few trips of my Residual Current breaker. I dug out my old Socket tester which tell me the three pins are correct. But then the Red warning light tells me my socket(s) fail the loop test. I never had this before but my last house had an overhead supply with no Earth from the company. The tester said "get this checked" and the man said the (high but not ridiculous) earth resistance was acceptable. I stuck a new copper earth...
Thread 'Beauty of old electrical and measuring things, etc.'
Even as a kid, I saw beauty in old devices. That made me want to understand how they worked. I had lots of old things that I keep and now reviving. Old things need to work to see the beauty. Here's what I've done so far. Two views of the gadgets shelves and my small work space: Here's a close up look at the meters, gauges and other measuring things: This is what I think of as surface-mount electrical components and wiring. The components are very old and shows how...
