Why Does Antimatter Exist if It's Not Found in Nature?
  • Thread starter cjackson
  • Tags
    Antimatter
In summary, antimatter exists only in the laboratory through synthesis and follows the left-handed rule of chirality, unlike matter which follows the right-handed rule. This is due to the fact that only the weak interaction cares about chirality and it only interacts with left-handed particles. Anti-matter and matter are identical in every aspect except for charge and other quantum numbers. There was a slight excess of matter particles that survived the mutual annihilation with antimatter after the big bang, which is still a mystery in science and is attributed to a possible unknown form of CP violation.
cjackson
39
I don't understand why antimatter exists in the first place. Could you explain why and how an asymmetry developed between matter and antimatter?
Dirac was the first to realize the relativistic version of the Schrodinger wave equation permitted anti particle counterparts to ordinary particles. We now know anti particles are routinely produced by high energy collisions between particles, and that anti matter should have existed in equal quantities shortly after the big bang. For reasons unknown, a slight excess [roughly one in a million] of matter particles survived the mutual annihilation frenzy that followed. The reason for this asymmetry is one of the great mysteries in science. Some as of yet unknown form of CPT violation is the prime suspect.
You mean CP violation, right?
Anti-matter exists only in the laboratory - artificially - through synthesis.
Matter and Antimatter are absolutely identical and indistinguishable in every aspect
other than charge.
Helium is composed of 2 (+) protons, 2 neutrons and 2 (-) electrons
Anti-Helium is composed of 2 (-) Anti-protons, 2 neutrons and 2 (+) positrons (anti-electrons)
The reason matter exists in nature and Anti-matter has to be synthesized
is due to Chirality (helical oriention) All matter follows the right-handed rule of chirality,
Anti-matter follows the left-handed rule of chirality, and is not found in nature.
Absolute symmetry is allowed in mathematics - in the Dirac equation for example,
however this is not true of all interactions in nature.
Equations are only abstract tools for calculating interactions in nature,
Equations do not describe the causes of interactions, nor can they explain a natural phenomenon.
Causes are the domain of practical experimental physics and not theoretical mathematics.
For antiHe you need antineutrons. They are not the same as neutrons. Two neutrons meeting together will not annihilate, while a neutron with antineutron can annihilate .
Also it would be much easier and more illustrative to speak of electron and positron, rather than going to a composite system.
Correct, this was only a simplified explanation of the principle
Anti-Neutrons are composed of Antiquarks and Neutrons are composed of Quarks
this is the only difference - and is also due to Chirality.
Positrons and antiprotons exist in nature, they are just rare and if they hit matter (like earth) they annihilate quickly.
other than charge.
And all other quantum numbers. And they are not absolutely identical, there is CP violation.
This is just wrong. Only the weak interaction cares about chirality at all, and this interacts only with left-handed fermions ("matter"), not with right-handed.
How is it "simplified" to list wrong particles?
Are you saying that there was no antimatter just after the big bang singularity or do you somehow exclude that from "found in nature" ?
1. What is antimatter?
Antimatter is a type of matter that is composed of particles with the same mass as regular matter, but with opposite charge. This means that antimatter particles, such as antiprotons and positrons, have a positive charge instead of a negative charge like regular matter particles.
2. Why does antimatter exist?
Antimatter exists because it is predicted by the fundamental laws of physics, specifically the Standard Model of particle physics. According to this model, for every particle of matter, there is a corresponding antiparticle of antimatter with the same mass and opposite charge. This is known as the principle of charge-parity symmetry.
3. How is antimatter created?
Antimatter can be created through high-energy collisions between particles, such as in particle accelerators, or through certain types of radioactive decay. It can also be produced naturally in small amounts, such as in cosmic rays from outer space.
4. What are the potential uses of antimatter?
Antimatter has the potential to be used as a powerful source of energy, as its annihilation with regular matter produces a large amount of energy. It is also used in medical imaging, such as in PET scans, and in scientific research to study the fundamental properties of matter.
5. Is antimatter dangerous?
While antimatter may sound dangerous due to its ability to release large amounts of energy, it is actually difficult to create and store in significant quantities. Additionally, when antimatter comes into contact with regular matter, it annihilates and releases energy, making it relatively safe to handle in controlled environments.
  • Astronomy and Astrophysics
