Energy of atomic orbitals in multielectron system
In summary, the concept of energy in atomic orbitals in a multielectron system is influenced by the attraction of the nucleus and repulsion of other electrons. The energy of atomic orbitals is affected by the shielding effect, which results in higher energy levels for outer electrons. This energy plays a crucial role in determining electron configuration, chemical properties, and bonding in atoms and molecules. It is calculated using the Schrödinger equation and can be indirectly observed through spectroscopic techniques.
keep@science
although the distance from the nucleus and shielding effect [due to more angular volume] is more for 4s orbital than a 3d orbital ,but yet the energy for a 3d orbital is more than 4s orbital, why?
Welcome to PF;
You mean as in:
It is due to angular momentum and spin.
http://antoine.frostburg.edu/chem/senese/101/electrons/faq/4s-3d.shtml
1. What is the concept of energy in atomic orbitals in a multielectron system?
In a multielectron system, each electron is influenced by the attraction of the nucleus and the repulsion of the other electrons. This results in the energy of atomic orbitals being different from that of a single-electron system.
2. How does the energy of atomic orbitals change in a multielectron system?
The energy of atomic orbitals in a multielectron system is affected by the shielding effect, which occurs when inner electrons block the attraction of the nucleus on outer electrons. This results in the outer electrons having a higher energy compared to those in a single-electron system.
3. What is the significance of the energy of atomic orbitals in a multielectron system?
The energy of atomic orbitals in a multielectron system determines the electron configuration and chemical properties of an atom. It also plays a crucial role in chemical bonding and the formation of molecules.
4. How is the energy of atomic orbitals in a multielectron system calculated?
The energy of atomic orbitals in a multielectron system is calculated using the Schrödinger equation, which takes into account the electrostatic interactions between the electrons and the nucleus, as well as the repulsion between electrons.
5. Can the energy of atomic orbitals in a multielectron system be observed or measured?
The energy of atomic orbitals in a multielectron system is not directly observable or measurable. However, it can be indirectly determined through spectroscopic techniques, such as X-ray spectroscopy, which measure the energy differences between different atomic orbitals.
  • Atomic and Condensed Matter
  • Other Physics Topics
