Electric Field Help: Find Magnitude & Direction
To find the electric field magnitude from a charge of 3 x 10–6 coulombs at a distance of 9 meters, the calculation should yield a value in N/C, not N. The correct formula for the electric field is E = F/q, where F is the force and q is the charge. The direction of the electric field is outward for positive charges. The discussion highlights the importance of using the correct units and understanding the electric field's definition. Overall, the problem requires calculating the electric field generated by the charge at the specified distance.
Linco
Can someone tell me if I got this right?
If a charge of 3 x 10–6 coulombs sets up an electric field, find:
a.The magnitude of the field 9 meters away.
F=K(q1q2/d*2) F= 9 X 10*9(3 x 10*6/9*2) =3.33N
b.The directive of the field.
The directive would be outwards.
Do you know what's the electric field?, on a) you wrote the coulombian force definition, applied the electric field definition, and used the wrong unit and used the wrong unit for electric field...
The problem didn't supply the electric field.
So I am guessing I need to use E=F/q?
im not sure how to do this without E
I suppose the problem is asking for the Electric Field supplied by the given charge at a distance of 9 meters, you found the magnitude, except your unit is wrong, it's N/C. Remember the Electric field is the amount of coulombian force per charge. You can find the direction throught the electric field convention, for positive charges the electric field lines are directed outwards.
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
Thread 'A bead-mass oscillatory system problem'
I can't figure out how to find the velocity of the particle at 37 degrees. Basically the bead moves with velocity towards right let's call it v1. The particle moves with some velocity v2. In frame of the bead, the particle is performing circular motion. So v of particle wrt bead would be perpendicular to the string. But how would I find the velocity of particle in ground frame? I tried using vectors to figure it out and the angle is coming out to be extremely long. One equation is by work...
