Do circuits need to be used in Radar related hardware?
Circuits are essential in most radar applications, particularly in the transmitter, which emits RF energy, and the receiver, which is a low-noise, high-gain RF radio receiver. Electronic timing circuitry is crucial for measuring echo return times to determine distance, especially in Doppler radar systems that calculate the speed of objects. While some radar systems can be passive, using electromagnetic principles without traditional circuits, the majority of low-power radar components rely on circuit technology. Overall, circuits play a significant role in the functionality and efficiency of radar hardware. Understanding the balance between circuit use and electromagnetic principles is key in radar technology.
redgoat
I'm not sure I understand your question, but for regular radar applications, several circuit types are used. The transmitter uses a tube like your microwave oven to send out pulses of RF energy through the antenna structure, and the receiver is a low-noise, high-gain RF radio receiver. Then there is the electronic timing circuitry that times the echo return time to determine the distance. For Doppler-capable (speed sensing) radar, the receiver and timing circuitry work together more closely to calculate the speed of the reflecting object.
But some radar structures can be completely passive. Like the wind-driven hidden cube corner things that will blank out police doppler radar detectors... (but don't help against LIDAR obviously).
Since radar uses microwaves, from the output device until the antenna you have a system that uses electromagnetism and not circuits. Instead of the laws of Kirchoff you use the laws of Maxwell.
But most of the low power portion of the radar system uses circuits.
I think circuits are used in radar.
Hey guys. I have a question related to electricity and alternating current. Say an alien fictional society developed electricity, and settled on a standard like 73V AC current at 46 Hz. How would appliances be designed, and what impact would the lower frequency and voltage have on transformers, wiring, TVs, computers, LEDs, motors, and heating, assuming the laws of physics and technology are the same as on Earth?
While I was rolling out a shielded cable, a though came to my mind - what happens to the current flow in the cable if there came a short between the wire and the shield in both ends of the cable? For simplicity, lets assume a 1-wire copper wire wrapped in an aluminum shield. The wire and the shield has the same cross section area. There are insulating material between them, and in both ends there is a short between them. My first thought, the total resistance of the cable would be reduced...
I used to be an HVAC technician. One time I had a service call in which there was no power to the thermostat. The thermostat did not have power because the fuse in the air handler was blown. The fuse in the air handler was blown because there was a low voltage short. The rubber coating on one of the thermostat wires was chewed off by a rodent. The exposed metal in the thermostat wire was touching the metal cabinet of the air handler. This was a low voltage short. This low voltage...
