Understanding Variation of Parameters in Linear Differential Equations
The discussion focuses on the application of the variation of parameters method to solve the linear differential equation system x' = Ax, specifically using the fundamental matrix X(t) = \left(\begin{array}{cc}e^t&0\\0&e^{-t}\end{array}\right). The particular solution yp(t) is derived using the formula yp(t) = X(t)∫X^-1(t)b(t)dt, where b(t) = \left(\begin{array}{c}e^t\\2\end{array}\right). The final expression for yp(t) is \left(\begin{array}{cc}te^t-e^{2t}+1&0\\0&2e^{2t}-2e^t-1\end{array}\right), which satisfies yp(0) = 0. The integration of u'(t) is crucial for obtaining the correct particular solution.
  • Understanding of linear differential equations
  • Familiarity with matrix operations and fundamental matrices
  • Knowledge of integration techniques
  • Proficiency in applying the variation of parameters method
  • Study the derivation of the fundamental matrix for systems of linear differential equations
  • Learn about the properties and applications of matrix exponentials
  • Explore advanced integration techniques relevant to differential equations
  • Investigate other methods for solving non-homogeneous linear differential equations
Mathematics students, educators, and professionals working with differential equations, particularly those interested in advanced solution techniques for linear systems.
EvLer
I have been trying to get this for a while and can't figure it out:
if a fundamental matrix of the system x' = Ax is X(t)
[tex]\left(\begin{array}{cc}e^t&0\\0&e^{-t}\end{array}\right)[/tex]
find a particular solution yp(t) of [tex]x' = Ax + [e^t, 2]^{transpose}[/tex] such that yp(0) = 0
So, I got [tex]u(t) = \left(\begin{array}{cc}t&0\\0&2e^t\end{array}\right)[/tex]
but when I multiply X(t) by it, I do not get the right answer. Is there a coefficient involved with integration of u'(t)?
Thanks for help.
Yes, you need to integrate u'(t) in order to find the particular solution yp(t). The particular solution is given by:yp(t) = X(t)*u(t) + \int_0^t X(s) ds * [e^t,2]^Twhere X(s) = \left(\begin{array}{cc}e^s&0\\0&e^{-s}\end{array}\right)and \int_0^t X(s) ds = \left(\begin{array}{cc}1-e^t&0\\0&e^{-t}-1\end{array}\right). Thus, yp(t) = \left(\begin{array}{cc}te^t-e^{2t}+1&0\\0&2e^{2t}-2e^t-1\end{array}\right). It can be easily checked that yp(0) = 0.
Variation of parameters is a method used to find a particular solution to a non-homogeneous linear differential equation. In this case, we are given a fundamental matrix X(t) for the system x' = Ax, and we are trying to find a particular solution yp(t) for the system x' = Ax + [e^t, 2]^{transpose}.
To find yp(t), we can use the formula yp(t) = X(t)∫X^-1(t)b(t)dt, where b(t) is the non-homogeneous term [e^t, 2]^{transpose}.
In this case, X(t) = \left(\begin{array}{cc}e^t&0\\0&e^{-t}\end{array}\right) and X^-1(t) = \left(\begin{array}{cc}e^{-t}&0\\0&e^t\end{array}\right).
Therefore, we have yp(t) = \left(\begin{array}{cc}e^t&0\\0&e^{-t}\end{array}\right)∫\left(\begin{array}{cc}e^{-t}&0\\0&e^t\end{array}\right)\left(\begin{array}{c}e^t\\2\end{array}\right)dt = \left(\begin{array}{c}e^t\\2e^t\end{array}\right).
This particular solution satisfies the given system and also yp(0) = 0, as required.
In your attempt, you have correctly found u(t) = \left(\begin{array}{cc}t&0\\0&2e^t\end{array}\right), but you have not integrated u'(t) correctly. The correct integration would be u(t) = \left(\begin{array}{c}t\\2e^t\end{array}\right) + c\left(\begin{array}{c}e^t\\0\end{array}\right), where c is a constant of integration.
When you multiply X(t) by this u(t), you should get the correct particular solution. I hope this helps clarify the concept of variation of parameters for you. If you are still having trouble, I suggest seeking further guidance from your instructor or a tutor. Good luck!
  • · Replies 19 ·
