Physics Forums Logo
* Register * Upgrade Blogs Library Staff Rules Mark Forums Read
image   image
Go Back   Physics Forums > Physics > Special & General Relativity
Reply
image Minkowski spacetime interval's Lorentz invariance Share It Thread Tools Search this Thread image
Old Aug5-05, 10:50 PM                  #1
cefarix
cefarix is Offline:
Question Minkowski spacetime interval's Lorentz invariance
Maybe this is really easy, but...
Can someone show me how the sign reversal between the space and time components of Minkowski spacetime make its intervals Lorentz invariant (mathematical derivation) ? Thanks....
Old Aug6-05, 03:08 AM                  #2
Mortimer
Mortimer is Offline:
Assuming that you are familiar with the Lorentz transformation equations themselves (object moving along x):
LaTeX Code: xsingle-quote=\\gamma(x-vt)
LaTeX Code: tsingle-quote=\\gamma(t-vx/c^2)
LaTeX Code: ysingle-quote=y
LaTeX Code: zsingle-quote=z
Lorentz invariance requires a space-time interval between two events to have the same magnitude from any frame so:
LaTeX Code: dssingle-quote^2=ds^2 .
If LaTeX Code: ds^2 would have been defined Euclidean as:
LaTeX Code: ds^2=c^2t^2+dx^2+dy^2+dz^2 ,
then this equation should have hold:
LaTeX Code: c^2t^2+dx^2+dy^2+dz^2=c^2tsingle-quote^2+dxsingle-quote^2+dysingle-quote^2+dzsingle-quote^2
If you solve the primed coordinates in this equation using the Lorentz transformation equations you end up with something that is clearly nonsense (check for yourself).
If on the other hand we define LaTeX Code: ds^2 Minkowskian:
LaTeX Code: ds^2=c^2t^2-dx^2-dy^2-dz^2 ,
then solving the primed coordinates leads to a correct result.
Another way to arrive at the LaTeX Code: +--- is using a lightpulse that spreads with speed LaTeX Code: c from the origin in all directions. A sphere is formed by this lightspreading according to:
LaTeX Code: c^2t^2=x^2+y^2+z^2 ,
so
LaTeX Code: c^2t^2-x^2-y^2-z^2=0 .
This is also true from a moving frame:
LaTeX Code: c^2tsingle-quote^2-xsingle-quote^2-ysingle-quote^2-zsingle-quote^2=0 ,
so
LaTeX Code: c^2t^2-x^2-y^2-z^2=c^2tsingle-quote^2-xsingle-quote^2-ysingle-quote^2-zsingle-quote^2 .
The rest of the story is the same but this last method was actually used to derive the Lorentz transformation equations in the first place.
Old Aug7-05, 05:17 PM                  #3
learningphysics
learningphysics is Offline:
Recognitions:
Homework Helper Homework Helper
I would do it this way. Take two events (t1,x1,y1,z1) and (t2,x2,y2,z2)
Using the lorentz transformations you can show that:
LaTeX Code: \\Delta tsingle-quote = \\gamma (\\Delta t - v\\Delta x/c^2)
LaTeX Code: \\Delta xsingle-quote = \\gamma (\\Delta x - v\\Delta t)
LaTeX Code: \\Delta ysingle-quote = \\Delta y
LaTeX Code: \\Delta zsingle-quote = \\Delta z
To get the above just use the lorentz transformations to calculate t1',x1'....t2',x2'... and then LaTeX Code: x2-x1 = \\Delta x and LaTeX Code: x2single-quote-x1single-quote = \\Delta xsingle-quote etc....
Now just calculate out:
LaTeX Code: c^2*(\\Delta tsingle-quote)^2 -(\\Delta xsingle-quote)^2-(\\Delta ysingle-quote)^2-(\\Delta zsingle-quote)^2 by substituting the above formulas. You'll see that it comes out to:
LaTeX Code: c^2*(\\Delta t)^2 -(\\Delta x)^2-(\\Delta y)^2-(\\Delta z)^2
Showing that the euclidean formula (with + instead of -) is not invariant is simple. Just take two events let's say (0,0,0,0) and (t1,0,0,0)
Now LaTeX Code: c^2*(\\Delta t)^2 +(\\Delta x)^2+(\\Delta y)^2+(\\Delta z)^2
comes out to LaTeX Code: c^2*t1^2
for S' it comes out to LaTeX Code: (c^2+v^2) (\\gamma)^2*t1^2
The two are not equal for nonzero v and t1.
image image
Reply
Thread Tools
Similar Threads for: Minkowski spacetime interval's Lorentz invariance
Thread Thread Starter Forum Replies Last Post
Definition of Minkowski spacetime ygor.geurts@gmail.com General Physics 6 Jun26-08 06:00 AM
Lorentz Transform in Non-Minkowski Spaces Ateowa Special & General Relativity 5 Dec5-07 09:43 AM
Lorentz Invariance and Non-Galilean Invariance of Maxwell's Equations Dahaka14 Classical Physics 4 Nov27-07 04:13 AM
Geodesics in Minkowski Spacetime Oxymoron Topology & Geometry 2 May10-06 05:09 AM
Why Minkowski spacetime and not Euclidean spacetime? cefarix Special & General Relativity 10 Aug8-05 11:15 PM
Powered by vBulletin Copyright ©2000 - 2010, Jelsoft Enterprises Ltd. © 2009 Physics Forums
Sciam | physorgPhysorg.com Science News Partner
image   image
