| Thread Closed |
Find the thickness of Aluminium Foil... |
Share Thread | Thread Tools |
| Sep6-05, 02:15 PM | #1 |
This question comes from my Grade 11 Univ. Physics Teacher.
Problem: To as many significant figures as you can justify, determine the thickness of the aluminium foil. 1. Purpose 2. Procedure 3. Calculations (Significant Figures) 4. Conclucion Now I know that the density of Aluminium is 2.7g/cm^3. And I also know that the formula for cm^3 is Length X Width X Thickness. So if i find the mass, multiply it by the density, and divide it by the length and the width, will I come out with the thickness? He said there are many ways to do this and this is the only one I could come up with so any input or help would be much appreciated. Regards; Patrick |
| Sep6-05, 02:42 PM | #2 |
Fold some foil over and measure with a micrometre and divide by number of folds
| Sep6-05, 03:35 PM | #3 |
Recognitions:
As a check-up, you can submerge it in water and measure displacement. Then work backwards from volume to thickness. If you perform both methods, then you can have a range (low estimate and high estimate). |
| Sep6-05, 07:00 PM | #4 |
| Sep7-05, 02:10 PM | #5 |
Measure the foil length and width and then place it into a full measuring cylinder and collect the displaced water. You now have the volume of foil, the length and width and so can find thickness
| Sep7-05, 02:53 PM | #6 |
Though you'll need a very accurate scale or a sizeable amount of foil to measure the mass accurately.
| Sep7-05, 08:57 PM | #7 |
Well I just measured the foil and I came out with 2.7 grams.
Here is what I have so far: Lenth: 30cm Width: 21cm Mass: 2.7g Density: 2.7g/cm^3. Am I missing any vital information? Im sorry to ask for help with it comes to the forumla and such, but I'm really stuck on this one, been working on it for 2 days :P I was told that you calculate the Area, (Length*Width*Height), then multiply together the Mass and the Density. *I got it. Thanks to all that helped, much appreciated :)* |
| Thread Closed |
| Thread Tools | |
Similar Threads for: Find the thickness of Aluminium Foil...
| Charged pen and aluminium foil | Advanced Physics Homework | 2 | ||
| Aluminum foil hats | General Discussion | 9 | ||
| Foil Helmets Can't Foil Government Mind Probes | General Discussion | 7 | ||
| to foil or not to foil | Introductory Physics Homework | 4 | ||
| Get your aluminum foil deflector beanie now! | General Discussion | 20 | ||
