Chem/Math Help: Solving Glaucoma Rx
  • Thread starter Thread starter Zed
A pharmacist needs to prepare 16 milliliters of eye drops with a 5% active ingredient using only 10% and 1% solutions. The equations x + y = 16 and 0.1x + 0.01y = 0.08 are set up to find the amounts of each solution needed. The correct calculations yield approximately 7.11 milliliters of the 10% solution and 8.89 milliliters of the 1% solution. There was confusion regarding the active ingredient calculations, with some participants mistakenly calculating the required amount. The final answers can be expressed as improper fractions, with 7.11 being equivalent to 7 and 1/9.
Zed
Chem/Math ! Help !
Hi ,
This is a Hw question i have am stuck on i don't know how to solve it ...
A pharmacist is to prepare 16 milliliters of special eye drops for a glaucoma patient. The eye-drop solution must have a 5% active ingredient, but the pharmacist only has 10% solution and 1% solution in stock.
How much of 10% solution should be used to fill the prescription?
How much of 1% solution should be used to fill the prescription?
please help
thx
Let x be the amount of 10% solution, in ml, and let y be the amount of 1% solution, also in ml.
"A pharmacist is to prepare 16 milliliters of special eye drops for a glaucoma patient. "
So x+ y= 16
"The eye-drop solution must have a 5% active ingredient"
In other words, the amount of the active ingredient must be 5% of 16 ml= 0.005*16= 0.08 ml.
The amount of active ingredient in x ml of a 10% solution is 0.1x.
The amount of active ingredient in y ml of a 1% solution is 0.01y
We must have 0.1x+ 0.01y= 0.08.
Solve x+ y= 16 and 0.1x+ 0.01y= 0.08 for x and y.
Shouldn't that be 0.05*16=0.8?
So x+ y= 16
thankx for ur reply ...
after solving it i got 0.8/0.09 but still its giving me answer wrong :S.. i tried solving this way before too still wrong.. although it says to write the answer as an improper fraction. how can i write a decimal as an improper fraction !
thx
Note i did use 5% of 16 as 0.8 so..i don't thinkt hats the problem
ok i found x and it turned out to be correct 7.111111111 which is equivelant to 7 and 1/9 as a mixed number...
am found y but its giving me wrong answer.. please tell me if am getting y wrong... i got y to be 8.888888889
Hey, arithmetic isn't my strong suit!
(And I couldn't find my calculator.)
