cscott
- 778
- 1
I'm trying to find a picture of a pre-transistor computer that I can compare to my iPod. Any help would be appreciated.
The discussion revolves around comparing pre-transistor computers, specifically the ENIAC, to modern devices like the iPod. Participants explore the specifications, historical context, and anecdotes related to early computing technology, including the concept of debugging.
Participants express a mix of agreement and skepticism regarding anecdotes about debugging and the historical context of early computing. There is no consensus on the specifics of how common issues like bugs in vacuum tubes were, nor on the exact bit architecture of the ENIAC.
Some claims about the historical context of debugging and the specifications of early computers depend on anecdotal evidence and may lack definitive sources. The discussion includes unresolved questions about the bit architecture of the ENIAC and the reliability of debugging stories.
(emphasis added)In 1946, John O. Eckert, John W. Mauchly of the University of Pennsylvania, built a high-speed electronic computer, known as ENIAC (Electrical Numerical Integrator And Calculator). It was successfully used by the Army to calculate trajectories of artillery shells.
ENIAC used 18,000 vacuum tubes which were short-lived, occupied a large room; technicians had to change the wiring in order to alter its program.
However, in spite of these limitations, ENIAC was fast (about 300 calculations/s) and was a success!
dduardo said:Google is your friend:
http://images.google.com/images?q=eniac&hl=en&btnG=Search+Images
300 calculations/second means the computer can execute 300 instructions per second. An instruction can be add, subtract, compare, etc.
Too bad the images only show the front end.. The business end (tube circuitry) would be of interest to me. I hear that is where they had to debug. Yes physically clean bugs out from between the tube circuits.dduardo said:Google is your friend:
Ouabache said:Too bad the images only show the front end.. The business end (tube circuitry) would be of interest to me. I hear that is where they had to debug. Yes physically clean bugs out from between the tube circuits.
You're catchin' on..Pengwuino said:That's where the term "computer bug" came from!
It is also worth pointing out that those are either 16 or 32bit instructions. Eniac was probably 8bit (not sure, but it can't be less, can it?).dduardo said:The ipod uses two ARM 7TDMI processors. Each is capable of 130MIPS => 130 million instructions per second.
http://www.history.navy.mil/photos/pers-us/uspers-h/g-hoppr.htmOuabache said:I hear that is where they had to debug. Yes physically clean bugs out from between the tube circuits.
I am not sure how common this was, http://www.cs.yale.edu/homes/tap/Files/hopper-story.html" tells of finding a moth caught in a relay, which caused a failure and hence the term "bug" was born. I'll bet it more of a unique event that a common occurrence.Ouabache said:Too bad the images only show the front end.. The business end (tube circuitry) would be of interest to me. I hear that is where they had to debug. Yes physically clean bugs out from between the tube circuits.
I first heard it mentioned in one of my computer design classes. I recall the prof handing out copies showing the working end (circuit side) of an ENIAC or similar machine . He told us that bugs had to be periodically cleaned from the tubes, coining the expression, debugging the system.Integral said:I am not sure how common this was, http://www.cs.yale.edu/homes/tap/Files/hopper-story.html" tells of finding a moth caught in a relay, which caused a failure and hence the term "bug" was born. I'll bet it more of a unique event that a common occurrence.
As the name implies, vacuum tubes are sealed, I am not sure how, even if the computer were running in the middle of a field, that a moth would cause the failure of a vacuum tube. I would consider that story a urban legend until proven otherwise. I leaned electronics in the vacuum tube days, so I am quite familiar with them. The filament glow of a vacuum tube is simply not bright enough to draw moths or any other bug. The computers of this era had to be ran in well cooled rooms, this generally implies some level of environmental control ie, limited access to bugs. While I tend to believe Grace Hoppers story (I heard her tell on a TV show a few years back) which involved a single bug (not stated what kind) caught in the contacts of a mechanical relay. I am skeptical of stories of many bugs immolating them selfs from the heat of a vacuum tube.Ouabache said:I first heard it mentioned in one of my computer design classes. I recall the prof handing out copies showing the working end (circuit side) of an ENIAC or similar machine . He told us that bugs had to be periodically cleaned from the tubes, coining the expression, debugging the system.
Here is an online description:
"Because the tubes actually glowed and gave off heat, they attracted moths and other bugs, which caused short circuits. Scientists would have to periodically "debug," which literally meant shutting down the computer and cleaning out the dead bugs (which is why still to this day, fixing computer problems is called debugging)." http://www.physics.ucla.edu/~ianb/history/
The mechanism of failure for a tube circuit is analogous to a modern circuit. Since you are familiar with tube circuits, let me describe for our PF readership, tubes are plugged into sockets. Those sockets are wired to the rest of the circuit (i.e. to other tubes and various components resistors, capacitors, etc...) When bugs get too close to a hot tube, or between high voltage connections, they will fry and accumulate. As bugs are composed of organic compounds and charged salts, they can cause a short between two points that are not supposed to be connected, potentially causing errors to develop in the program.Integral said:As the name implies, vacuum tubes are sealed, I am not sure how, even if the computer were running in the middle of a field, that a moth would cause the failure of a vacuum tube.
Here I differ with your thoughts. I’m also familiar with vacuum tube circuits and observed them glowing plenty bright, to attract insects. And the infrared radiation (heat) of a vacuum tube will also attract bugs. (For those curious about vacuum tube circuits, you can find good working broadcast tube-radios and older amateur radio transmitters and recievers, that work as well today as they did in their heyday. Enthusiasts affectionately refer to the tubes as bottles that glow in the dark).I leaned electronics in the vacuum tube days, so I am quite familiar with them. The filament glow of a vacuum tube is simply not bright enough to draw moths or any other bug.
Yes jtbell also posted the same reference on this thread. In my last post you will see, I quoted a http://www.physics.ucla.edu/~ianb/history/, from the physics department at UCLA. I give them more credibility than describing their information as urban legend.I would consider that story a urban legend until proven otherwise….
While I tend to believe Grace Hoppers story (I heard her tell on a TV show a few years back) which involved a single bug (not stated what kind) caught in the contacts of a mechanical relay. I am skeptical of stories of many bugs immolating them selfs from the heat of a vacuum tube. Here is Grace Hoppers verision, including a picture of the moth taped to the lab book.
