205.23 related rates sphere volume
In summary, the formula for calculating the volume of a sphere is V = (4/3)πr³, and the related rates formula for finding the rate of change of the volume is dV/dt = (4/3)π(3r²)(dr/dt). In "205.23 related rates sphere volume", the constant 205.23 represents the rate of change of the radius (dr/dt). To solve for the rate of change of the volume, we use the related rates formula and plug in the value of dr/dt.
karush
MHB
3,269
$\tiny {205.23} $
$\text{ The volume }\displaystyle V=\frac{4}{3}\pi{r}^{3}
\text{ of a spherical balloon changes with the radius.} $
$\text{a) at what rate } \displaystyle \frac{ft^3}{ft} \\$
$\text{does the volume change with respect to the radius when $r=2 ft.$} $
$$\d{V}{f}=4\pi{r}^{2}\d{r}{f}\implies\d{V}{r}=4\pi{r}^{2} $$
$\text{at $r=2ft $ then} $
$$\d{V}{r}=4\pi{2}^{2} =16\pi \frac{ft^3}{ft} $$
$\text{b)how much does the volume increase when the}$
$\text{radius increases from $2$ to $2.3 ft$}$
$\displaystyle 4\pi(2.3^2)-16\pi\approx16.21 \frac{ft^3}{ft} $
$\text{so far ??}$
The units you are using for the rate of change of the volume should be the cube of a linear measure divided by a time measure, such as ft³ / s. If we choose to use seconds as the time measure, then:
\(\displaystyle \d{V}{t}=4\pi r^2\,\frac{\text{ft}^3}{\text{s}}\)
Hence:
\(\displaystyle \left.\d{V}{t}\right|_{r=2}=4\pi (2)^2\,\frac{\text{ft}^3}{\text{s}}=16\pi\,\frac{\text{ft}^3}{\text{s}}\)
To find the exact change in volume when the radius increases from $r=2$ to $r=2.3$, we could simply write:
\(\displaystyle \Delta V=V(2.3)-V(2)=\frac{4}{3}\pi(2.3^3-2^3)\text{ ft}^3=\frac{4}{3}\pi\cdot\frac{4167}{1000}\text{ ft}^3=\frac{1389}{250}\pi\text{ ft}^3\)
If we wish to use a linear approximation, we could write:
\(\displaystyle \d{V}{r}=4\pi r^2\)
\(\displaystyle \Delta V\approx\d{V}{r}\Delta r=4\pi r^2\Delta r\)
With $r=2$ and $\Delta r=\frac{3}{10}$, we obtain:
\(\displaystyle \Delta V\approx\frac{24}{5}\pi\text{ ft}^3\)
I thought so too but the problem actually says
\(\displaystyle \frac{ft^3}{ft}\) don't see any time unit given
$\tiny {205.23} $
$$\d{V}{r}=4\pi{(2)}^{2} =16\pi \frac{ft^3}{ft} $$
$\displaystyle V(2.3)-V(2) \approx 17.46 {ft}^{3} $
At first I thought the problem as given had a typo, but now I believe I understand what is intended. We are just to consider a change in the radius, not a change in the radius with respect to time. I apologize for the confusion. :eek:
quite understandable, normally I'm sure its related to time
but your post still was very helpful, as always giving clearer insight to what seems so daunting at times. which is missing to often in the class room.,😎
karush said:
$\tiny {205.23} $
Yes, that is the correct rate of change of volume with respect to the radius.
$\text{so far ??}$
No, that is how much the rate of volume increase increases!
When r= 2, the volume is [tex](4/3)\pi r^3= (4/3)\pi (2^3)= (4/3)\pi (8)= (32/3)\pi \approx 25.13[/tex] cubic feet. When r= 2.3 the volume is [tex](4/3)\pi r^3= (4/3)\pi (2.3^3)= (4/3)\pi (12.162)\approx 50.96[/tex] cubic feet. The volume increases by approximately 50.96- 25.13= 25.82 cubic feet.
Related to 205.23 related rates sphere volume
1. How do you calculate the volume of a sphere in "205.23 related rates"?
To calculate the volume of a sphere in "205.23 related rates", you would use the formula V = 4/3πr³, where V is the volume and r is the radius of the sphere. This formula remains the same regardless of whether the sphere is involved in a related rates problem or not.
2. Can you explain the concept of related rates in the context of a sphere's volume in "205.23 related rates"?
In the context of "205.23 related rates", related rates refer to the change in one quantity (such as the volume of a sphere) in relation to the change in another quantity (such as the radius of the sphere). This means that as the radius changes, the volume of the sphere also changes, and we can use this relationship to solve related rates problems.
3. What are the steps to solve a related rates problem involving the volume of a sphere in "205.23 related rates"?
The steps to solving a related rates problem involving the volume of a sphere in "205.23 related rates" are as follows:
1. Identify the known and unknown quantities
2. Write down the relevant formula (V = 4/3πr³)
3. Take the derivative of both sides with respect to time (dV/dt = 4πr²(dr/dt))
4. Substitute the known values into the equation
5. Solve for the unknown rate (dV/dt)
6. Check your units and answer for reasonableness.
4. How does the volume of a sphere in "205.23 related rates" change as the radius changes?
In "205.23 related rates", the volume of a sphere changes as the radius changes because they are directly related. As the radius increases, the volume will also increase, and as the radius decreases, the volume will decrease. This relationship can be represented mathematically with the equation dV/dt = 4πr²(dr/dt), where the change in volume is equal to the surface area of the sphere (4πr²) multiplied by the rate of change of the radius (dr/dt).
5. What are some real-life applications of related rates involving the volume of a sphere in "205.23 related rates"?
Related rates involving the volume of a sphere in "205.23 related rates" can be applied in various real-life situations, such as:
1. Calculating the rate of change of a soap bubble as it expands
2. Determining the rate at which a water droplet evaporates
3. Monitoring the inflation rate of a balloon
4. Estimating the rate at which a tumor grows
5. Calculating the rate at which a snowball melts.
  • Calculus
  • Calculus
