A Commuter Diode Explanation Problem
In summary, the diagram in the article is correct when viewing it from an electron flow perspective, but the arrows should point in the opposite direction.
cybershark5886
I have been trying to figure how a commuter diode effectively works in a circuit with a coil. I know that once the electric/magnetic field collapses in the coil after the current is cut to it that it induces a current in the opposite direction on the diode, which can only travel one way. But when trying to read up on an article with diagrams on this fairly simple circuit, I either got really confused or the people drew the diagram wrong.
Check out this very small article to see what I am talking about: http://www.allaboutcircuits.com/vol_3/chpt_3/8.html.
Shouldn't the 4th diagram (the post-collapse diagram) have the current arrows going in the opposite direction and the polarity signs on the diode switched (thus staying the same in the 3rd diagram - because the diode cannot switch polarity)? Or am I just reading it wrong. The current in a diode travels in the direction where the arrow symbol points, right?
Maybe one of you could help me out in trying to understand how that circuit works. It seems simple but I can't figure it out with that article.
there is such a thing as conventional current flow and electron flow theory ,
http://www.mi.mun.ca/~cchaulk/eltk1100/ivse/ivse.htm
this site explains the difference..in engineering we use conventional current flow..
your site uses the other system..
in conventional current flow , the current flows out of the positive battery terminal..
The diagram is correct when viewing from an electron flow perspective. Frankly, I've not met anyone who uses "conventional" current flow, but that may just be due to the community I work in.
Just ignore the arrows and follow the polarity signs, maybe that will help.
man this place is dead.
i thought it was bad before , but holy crap its positively comatose !
Dngrsone, really ? we sort of learned both ., but conventional was by far the majority..
it must be weird when using diodes, having to go against the arrow ,all the time..??
I too have rarely come across electron flow (as opposed to conventional current) pictures, but that's clearly what the site linked by the OP is doing.
We learned that the arrow pointed to the N-doped silicon :rolleyes:
Conventional theory was briefed to my class, but we were taught electron flow theory because it's the way electronics "really works" and also because it's almost indispensable for vacuum-tube theory, which we learned before going into transistor theory.
My instructor was a hard scinece/physics type, so he taught us how everything worked according to the reigning knowledge of the day. I have since relearned things a little differently (but clearer in my brain) here. Keep in mind, this is still electron flow theory.
Related to A Commuter Diode Explanation Problem
1. What is a commuter diode and why is it important?
A commuter diode is a type of diode that allows current to flow in only one direction, making it a valuable component in electrical circuits. It is crucial in preventing damage to sensitive electronic devices by regulating the flow of electricity.
2. How does a commuter diode work?
A commuter diode has two terminals, an anode and a cathode. When a voltage is applied to the anode, it allows current to flow through the diode. However, if the voltage is reversed, the diode blocks the flow of current, acting as a one-way gate for electricity.
3. What are some common applications of commuter diodes?
Commuter diodes are commonly used in rectifier circuits to convert AC (alternating current) power to DC (direct current) power. They are also used in power supplies, voltage regulators, and electronic devices such as laptops, smartphones, and LED lights.
4. What are the differences between a commuter diode and a regular diode?
The main difference between a commuter diode and a regular diode is the direction of current flow. A regular diode allows current to flow in only one direction, but a commuter diode has a specific polarity and only allows current to flow in one direction while blocking it in the other.
5. How can I determine the polarity of a commuter diode?
The polarity of a commuter diode can be determined by looking at the markings on the diode. The anode is typically marked with a positive (+) symbol, while the cathode is marked with a negative (-) symbol. If there are no markings, the longer terminal is usually the anode, and the shorter one is the cathode.
  • Electrical Engineering
9K
