Accretion disk around galaxy NGC 4261
The accretion disk surrounding galaxy NGC 4261 features a cold outer region transitioning to an ultra-hot inner disk near the suspected black hole. The dark, dusty material in the outer disk is expected to heat up and emit bright radiation in the UV and X-ray spectrum due to the high temperatures. However, images taken at visible wavelengths do not capture this brightness, as dust radiates at the frequency of the light it absorbs. Thus, the lack of brightness in visible images is consistent with the properties of dust. The discussion highlights the relationship between temperature, dust, and radiation in astrophysical contexts.
JeffOCA
Hello,
When you look at the accretion disk around NGC 4261 (see here), you can read that the dark, dusty disk represents a cold outer region which extends inwards to an ultra-hot accretion disk with a few hundred million miles from the suspected black hole.
So, from the outside, you have successively a bright ring, then a dark dusty ring and "an ultra-hot accretion disk" very close to the center black hole itself.
My question : due to the ultra-hot temperature in the accretion disk, the dark material (dust) is extremely heated and, so, should radiate in a very bright way (UV and/or X-rays). Why not ?
Regards
JF
Astronomy news on Phys.org
Ok, the picture link I posted is taken at visible wavelengths that why dust material is not bright. Am I right ?
Regards
JF
Yes. Dust tends to radiate at the frequency of light it receives.
This thread is dedicated to the beauty and awesomeness of our Universe. If you feel like it, please share video clips and photos (or nice animations) of space and objects in space in this thread. Your posts, clips and photos may by all means include scientific information; that does not make it less beautiful to me (n.b. the posts must of course comply with the PF guidelines, i.e. regarding science, only mainstream science is allowed, fringe/pseudoscience is not allowed). n.b. I start this...
Today at about 4:30 am I saw the conjunction of Venus and Jupiter, where they were about the width of the full moon, or one half degree apart. Did anyone else see it? Edit: The moon is 2,200 miles in diameter and at a distance of 240,000 miles. Thereby it subtends an angle in radians of 2,200/240,000=.01 (approximately). With pi radians being 180 degrees, one radian is 57.3 degrees, so that .01 radians is about .50 degrees (angle subtended by the moon). (.57 to be more exact, but with...
