How Does the Affine Connection Contract in General Relativity?
In summary, Bill says that the last two terms in eq. (4.7.4) drop out because they are antisymmetric in μ and ρ. He also says that Weinberg uses both terms, although affine connection is a more general one.
coqui82
Hi everyone!
I have some problems with indices in general relativity. I am now working with the classic textbook by S. Weinberg and in eq. (4.7.4) we find
http://latex.codecogs.com/gif.latex...partial g_{\rho \mu }}{\partial x^{\lambda }}
The question is: where does the last equality come from?
I think that it could come from the comparison between this expression and the same one interchanging μ and ρ. In so doing you would get the same expression except for the last two partial derivatives that would change their sign. Now if you consider (I am not sure if this is right) that http://latex.codecogs.com/gif.latex?\Gamma^{\mu}_{\mu \lambda }=\Gamma ^{\rho }_{\rho \lambda } then it comes straightforwardly that http://latex.codecogs.com/gif.latex...partial g_{\mu \lambda }}{\partial x^{\rho }}
Thanks in advance!
(You can embed LaTeX code directly in your post by wrapping it with TEX or ITEX.)
Yes, you're correct, the reason the last two terms drop out is that they are antisymmetric in μ and ρ, and we're multiplying by gμρ which is symmetric.
Does Weinberg actually call the Christoffel symbols an affine connection :confused:?
Thanks a lot Bill! Much more clear now!
And yes, Weinberg uses both terms, although affine connection is a more general one.
What is wrong with this? :confused:
Related to How Does the Affine Connection Contract in General Relativity?
1) What is an affine connection contraction?
An affine connection contraction is a mathematical concept used in differential geometry to describe the change in a vector field along a given path. It is a measure of how much a vector changes as it is parallel transported along a curve in a manifold.
2) How is the affine connection contraction related to the Levi-Civita connection?
The Levi-Civita connection is a special case of the affine connection contraction, where the contraction is performed along a geodesic path. This connection is used in Riemannian geometry to define the notion of parallel transport and to study curvature.
3) What is the difference between a covariant derivative and an affine connection contraction?
A covariant derivative is a generalization of the derivative to curved spaces, while an affine connection contraction is a specific type of covariant derivative that measures the change in a vector field along a path. The affine connection contraction is a more specialized concept, while the covariant derivative has a broader scope.
4) How is the affine connection contraction used in general relativity?
In general relativity, the affine connection contraction is used to define the Christoffel symbols, which are used to calculate the curvature of spacetime. This curvature is related to the distribution of matter and energy in the universe, and is used to describe the gravitational field.
5) What is the importance of the affine connection contraction in differential geometry?
The affine connection contraction is an important concept in differential geometry because it allows us to study the behavior of vectors and tensors on curved spaces. It is used in various fields such as relativity, differential equations, and differential topology to study the properties of manifolds and their curvature.
  • Linear and Abstract Algebra
