Amount of Phytoplankton in Sea Water
  • Thread starter Thread starter Sundog
Phytoplankton biomass in seawater, particularly around reefs and near the surface, is typically measured using satellite telemetry that assesses chlorophyll levels, which are then converted to biomass estimates. This biomass is highly variable, influenced by seasonal algal blooms in temperate waters, with significant fluctuations occurring throughout the year. Phytoplankton is generally concentrated within the upper 30 meters of the water column, with the highest concentrations found near the surface during midday. Global estimates suggest that the total biomass of phytoplankton in the oceans is around 5 to 10 billion tonnes of carbon, representing about 1% of the global biomass. In smaller, closed systems like ponds, phytoplankton concentrations are often reported in terms of chlorophyll content, which can then be used to derive biomass estimates. Overall, the measurement of phytoplankton is complex and subject to significant temporal and spatial variability.
Sundog
Does anyone know how much phytoplankton is in sea water? Say surrounding reefs and near the surface? I couldn’t find a number so I don’t know if it would be in ppm or something els.
Thanks!
Biology news on Phys.org
Sundog said:
how much
Are you measuring in individuals per (? (what unit of distance or area?)).
Phytoplankton biomass is often measured by satellite telemetry, based on chlorophyll levels in the uppermost water column. And then converted to biomass.
In Northern (and Southern) temperate waters, there is what is called an 'algal bloom' in the late meteorological spring. Another smaller bloom occurs in late summer. For these reasons and many others, phytoplankton biomass is ephemeral (comes and goes by orders of magnitude) value in a given ecosystem. In other words, it is a value that can change often. And a lot. So estimates are often a percent of total biomass.
And measurements are affected by the vertical movement of plankton in the water column. -- vertical distribution of the organisms changes by time of day, and one gets varying results over the duration of a day, since the top layer is what is measured by telemetry. Bathymetric (depth measuring) devices that sample water as well as depth, can bring small samples to the surface. Phytoplankton is usually within ~30m of the surface (depends on time of year, water temperature, nutrients, etc.), with the greatest concentration of phyto-beasties very near the surface during mid-day. In early June (or December).
Fuzzy answer from wikipedia:
Apart from bacteria, the total global biomass has been estimated at about 560 billion tonnes C. Most of this biomass is found on land, with only 5 to 10 billion tonnes C found in the oceans. ... It has been estimated that about 1% of the global biomass is due to phytoplankton, and 25% is due to fungi.
If you really want details, please read:
https://en.wikipedia.org/wiki/Biomass_(ecology)
Anyway, the phytoplankton biomass estimate works out to 5 billion metric tons of carbon, which is how biomass is reported. Not chlorophyll.
@Ivan Samsonov
Phytoplankton in a more closed system like a pond or a small given body of water is sometimes reported as Xminimum - Xmaximum mg/ml of chlorophyll - usually for a specified date range. And then a biomass estimate may (or may not) be derived from those values.
Whatever you could find or know. I can’t seem to find anything.
Thanks! Good info
https://www.nhs.uk/mental-health/conditions/body-dysmorphia/ Most people have some mild apprehension about their body, such as one thinks their nose is too big, hair too straight or curvy. At the extreme, cases such as this, are difficult to completely understand. https://www.msn.com/en-ca/health/other/why-would-someone-want-to-amputate-healthy-limbs/ar-AA1MrQK7?ocid=msedgntp&cvid=68ce4014b1fe4953b0b4bd22ef471ab9&ei=78 they feel like they're an amputee in the body of a regular person "For...
Thread 'Did they discover another descendant of homo erectus?'
The study provides critical new insights into the African Humid Period, a time between 14,500 and 5,000 years ago when the Sahara desert was a green savanna, rich in water bodies that facilitated human habitation and the spread of pastoralism. Later aridification turned this region into the world's largest desert. Due to the extreme aridity of the region today, DNA preservation is poor, making this pioneering ancient DNA study all the more significant. Genomic analyses reveal that the...
Whenever these opiods are mentioned they usually mention that e.g. fentanyl is "50 times stronger than heroin" and "100 times stronger than morphine". Now it's nitazene which the public is told is everything from "much stronger than heroin" and "200 times stronger than fentany"! Do these numbers make sense at all? How do they arrive at them? Kill thousands of mice? En passant: nitazene have already been found in both Oxycontin pills and in street "heroin" here, so Naloxone is more...
