Does the Variable ##t## Represent Multiple Concepts in Physics Problems?
kanekiyura
A rigid thin ring shaped like a circle of radius R rotates
uniformly around a fixed axis passing through one of the points of the circle and perpendicular to its plane. An ant crawls along the ring, moving all the time relative to the annulus with a constant velocity.At time t = 0, the velocity of the ant relative to a stationary observer is maximal and equal to v1.After time t, this velocity becomes minimal for the first time and equal to v2. Find the law of variation of the velocity value v(t).
I really don't know
I do not know how to solve this. All I got was to exclude the speed of the ant relative to the ring from the equation for its full speed
Hello @kanekiyura ,
:welcome:
Unfortunately, PF doesn't work this way. The PF guidelines dictate that you post your best attempt at solution before we are allowed to help.
Make some sketches that help you find ##v_1## and ##v_2##.
Likes MatinSAR
First, to be accurate, it's the ant's speed that can be constant relative to the periphery of the ring, not its velocity. The velocity keeps changing direction.
Can you write an equation for the velocity of the centre of the ring at time t? And an equation for the ant's velocity relative to the centre of the ring?
Likes MatinSAR and vela
Is there consensus that symbol ##t## is used rather carelessly to stand for two different entities?
1. A specific time at which the "velocity becomes minimal for the first time and equal to v2."
2. The independent variable in "the law of variation of the velocity value v(t)."
If that is the case, then perhaps a clearer formulation of the relevant section might be
At time ##t = 0##, the velocity of the ant relative to a stationary observer is maximal and equal to ##v_1.## At time ##t=t_2## this velocity becomes minimal and equal to ##v_2##. Find the law of variation of the velocity ##v(t).##
Likes nasu, haruspex and MatinSAR
1. Is the variable t always used to represent time in physics problems?
No, the variable t can represent various concepts in physics problems, not just time. It can also represent temperature, tension, or any other quantity depending on the context of the problem.
2. How can I determine what the variable t represents in a physics problem?
To determine what the variable t represents in a physics problem, you should carefully read the problem statement and look for any clues or context provided. Sometimes the units or equations involved can also give you a hint.
3. Can the same variable t represent different concepts in different physics problems?
Yes, the variable t can represent different concepts in different physics problems. It all depends on how it is defined and used within the specific context of each problem.
4. Are there any standard conventions for using variables in physics problems?
While there are some common conventions for using variables in physics, such as using certain letters to represent specific quantities, there are no strict rules that dictate what each variable must represent. It ultimately comes down to how the variable is defined within the problem.
5. How can I avoid confusion when dealing with variables that represent multiple concepts?
To avoid confusion when dealing with variables that represent multiple concepts, it is important to carefully define and keep track of what each variable represents in each specific problem. Paying close attention to units and being consistent in your notation can also help clarify the meaning of each variable.
