Are there solutions to 4m^(n)=n^(2m) with m,n in Z+
  • Thread starter Thread starter megatyler30
The discussion centers on the equation 4m^n = n^(2m) and the search for integer solutions for m and n. The original poster explored the equation using Mathematica but found no solutions, suggesting that integer solutions may not exist. They noted that in a simpler case of x^y = y^x, the only integer solutions are 2 and 4. An edit revealed that m=1 and n=2 is a solution, raising the question of whether it is the only integer solution. The implications of no integer solutions suggest that x^y + y^x + 1 may never be a perfect square.
megatyler30
Hi, thanks for taking the time to read.
To gain insight into n^m+n^m+1 and when it's prime, I looked at one case where it would be composite.
I equated it to (a+1)^2 and then substituted out to get 4m^n=n^{2m} Using mathematica, I was unable to get a solution. So here's my question: are there any solutions to it with integer n and m?
Mathematics news on Phys.org
By inspection, n=1 and m=2 or is that 2m an exponent?
2m is an exponent. I fixed it.
There's likely no integer solution. In the simpler case of x^y = y^x the only integer solution is 2 and 4.
My pocket CAS on iOS couldn't find any solutions either but it couldn't solve my easier one either.
Well that's pretty interesting since no integer solutions would imply that x^y+y^x+1 will never be a perfect square. Thank you.
Edit: Found m=1 and n=2 is a solution. I wonder if that's the only integer solution.
Suppose ,instead of the usual x,y coordinate system with an I basis vector along the x -axis and a corresponding j basis vector along the y-axis we instead have a different pair of basis vectors ,call them e and f along their respective axes. I have seen that this is an important subject in maths My question is what physical applications does such a model apply to? I am asking here because I have devoted quite a lot of time in the past to understanding convectors and the dual...
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. In Dirac’s Principles of Quantum Mechanics published in 1930 he introduced a “convenient notation” he referred to as a “delta function” which he treated as a continuum analog to the discrete Kronecker delta. The Kronecker delta is simply the indexed components of the identity operator in matrix algebra Source: https://www.physicsforums.com/insights/what-exactly-is-diracs-delta-function/ by...
