Atwood Machine, finding mass
In summary, the first block has a mass of 3.66kg and the second block is unknown. The blocks are released and block M accelerates at .255*g m/s2 downward. Find the mass of block M.
Kamisama
23
atwood machine: pulley with negligible mass and frictionless with 2 blocks hanging at rest.
The first block "m" has a mass of 3.66kg
The second Block "M" is unknown
The blocks are released; block M accelerates at .255*g m/s2 downward
Find the mass of block "M"
Hint: There are 2 solutions.
F=ma
a= (Mg-mg)/(m+M)
I rearranged the equation to M=m(a+g)/(g-a) and solved getting 6.17 as my first answer but I can't figure out how to get a second solution after trying a few different ways that which all lead me to 6.17 (pretty much different forms of the acceleration formula, kinda lost). How else can I get the mass of M with what I'm given? Also, was my first answer correct?
There is one equation and one unknown (and you've solved it). The equation is linear so there would be a unique answer. Possible the hint is wrong?
Likes Chestermiller
I don't think the hint is wrong. There are two answer boxes. I tried answering it with only one solution and it told me it was completely wrong with no partial credit which makes me think I'm completely off.
I also don't see two solutions coming out of this. Just to make sure, does the statement of the problem definitely say that the unknown mass accelerates downward?
I could well be wrong but I'm fairly certain the physics isn't determined by the number of solution boxes. A pulley (massless) a rope and 2 masses. The acceleration of the mass M is known (both magnitude and direction) and fixing the acceleration of m. Taking up as positive I get,
T - Mg = Ma,
where a = -0.255g for mass M and,
T - mg = -ma,
solving for M,
(m - M)g = (M+m)a
M = m(g - a)/(g+a)
one and only one solution
Yes, well rather the 2 blocks on the frictionless, massless pulley both accelerate at 0.255g m/s2 once they're released with M>m
Paul Colby said:
M = m(g - a)/(g+a)
M= (3.66)(9.81 -(-0.255*9.81)) / (9.81- 0.255*9.81) = 6.1655 = 6.17kg..
I did calculate this correctly, right?
Unfortunately it wants 2 answers. Is there another equation I could use?
I'm a little confused. In the original statement of the problem there was no mention of M being greater than m, but it did state that M accelerates downward.
Did you state the problem in post #1 exactly as given to you (word for word)?
I'm just trying to make sure that the problem statement states or implies that M accelerates downward.
We need to be completely clear on this. Are you saying that it does not specify the direction of acceleration, but that it does specify M>m? Maybe it would be best if you were to quote the complete question word for word. (Or is it a translation?)
It specifies that M > m which is why I said downward. Sorry for any confusion.
OK. Thanks. I don't see how there can be two answers. It still might be good if you quoted the problem exactly.
Likes Kamisama
2 blocks of masses m1 and m2 are suspended by a massless string over a frictionless pulley with negligible mass, as in an atwood machine . the blockss are held motionless and the released. if m1 = 3.66kg, what value does m2 have to have in order for the system to experience and acceleration a= .255g? (hint: there are two solutions to this problem)
word for word
There is no mention of M > m or M accelerating downward. So, see if you can see why there are in fact two solutions.
Likes Kamisama
ah I see now, my original thinking is that if m2 is to accelerate, it would only accelerate downward. How would i go about finding the other acceleration.
Assume the acceleration of M is upward?
Likes Kamisama
Well, that would make sense wouldn't it...haha
So for one,
and for the second one,
M= (3.66)(9.81-0.255*9.81) / (9.81+0.255*9.81) = 2.17kg
if my thought process is correct..
Looks good.
Thanks again for all your help as well as everyone else! I finally got it!
Good work and welcome to PF.
1. What is an Atwood Machine?
An Atwood Machine is a simple mechanical device that consists of two masses connected by a string or rope that passes over a pulley. It is used to demonstrate the principles of Newton's laws of motion.
2. How do you find the mass of an Atwood Machine?
The mass of an Atwood Machine can be found by using the equation: M = (m1-m2)/2, where M is the mass of the Atwood Machine, m1 is the mass on one side of the pulley, and m2 is the mass on the other side of the pulley.
3. What are the factors that affect the motion of an Atwood Machine?
The motion of an Atwood Machine is affected by the difference in mass between the two masses, the force of gravity, and the friction in the pulley system. In addition, the length and mass of the string can also affect the motion.
4. How is the acceleration of the Atwood Machine calculated?
The acceleration of an Atwood Machine can be calculated using the equation: a = (m1-m2)/(m1+m2), where a is the acceleration and m1 and m2 are the masses on each side of the pulley.
5. What are the practical applications of an Atwood Machine?
An Atwood Machine has practical applications in physics experiments and demonstrations. It is also used in engineering and design to study the effects of forces on moving objects. Additionally, it can be used in weightlifting machines and elevators to lift and lower objects.
