I Axion production via Bremsstrahlung - Simple maths question
Milsomonk
Hi all,
I am looking for clarification on what is probably a pretty basic change of variables between a few lines in the following paper:
https://journals.aps.org/prd/pdf/10.1103/PhysRevD.34.1326
Equation (9) shows the differential cross section for a Bremsstrahlung process which creates an axion instead of a photon, the cross section is expressed as a differential in ##x## where ##x=E_a/E_e##, the ratio of the emitted axion energy to initial electron energy. Between Equation (8) and (9) a change of variables takes place such that ##\frac{d\sigma}{d E_a} \rightarrow \frac{d\sigma}{d x}##. What is the correct process to reverse this change of variable so that I have the cross section expressed as differential in axion energy ##E_a##? I infer that the author must have done the following substitution (I express the particular algebraic form of the cross section as ##f## for brevity):
$$ \frac{d\sigma}{d E_a} = f(E_a/E_e) = f(x)$$
$$\frac{d\sigma}{d x} = \frac{d\sigma}{d E_a}\cdot \frac{dE_a}{dx} = f(x)* E_e$$
If this is correct, then to reverse the change of variables we have:
$$\frac{d\sigma}{d E_a} = \frac{d\sigma}{d x}*\frac{dx}{dE_a}=f(E_a/E_e)\frac{1}{E_e}$$
Or have I missed something?
It should be instead of ##f(E_a/E_c)##, ##f(x)*E_c##; so you are missing a factor of ##E_c## , but this of course is circular and you are back with what you started with. :cool:
This is an alert about a claim regarding the standard model, that got a burst of attention in the past two weeks. The original paper came out last year: "The electroweak η_W meson" by Gia Dvali, Archil Kobakhidze, Otari Sakhelashvili (2024) The recent follow-up and other responses are "η_W-meson from topological properties of the electroweak vacuum" by Dvali et al "Hiding in Plain Sight, the electroweak η_W" by Giacomo Cacciapaglia, Francesco Sannino, Jessica Turner "Astrophysical...
Hello everyone, I am seeking to better understand the conceptual foundations and potential consequences of "Two-Time Physics" (2T-physics), as developed by Itzhak Bars and others. My interest was sparked by a recent paper that attempts to explain anomalous results in particle physics (apparent superluminal propagation of virtual photons) within the framework of 2T-physics: Paper: https://arxiv.org/abs/2408.02696 Key quote from the abstract: *"...the problem... can be solved naturally...
