Banked roads -- circular motion and gravitation
In summary: My result is a little different because instead of using 88 m for the radius, I simply used 1.00 for the radius and converted g to m/sec². So my result is 0.214, which is pretty close.
MPat
If a curve with a radius of 88m is perfectly banked for a car traveling at 75km/h, what must be the coefficient of static friction for a car not to skid when traveling at 95 km/hr
75km/h = 20.8m/s
95km/h = 26.4m/s
Fr=mv^2/r
Fr=centripetal force
m = mass
r = radius
v = velocity
Fn= normal force
Ffr= force of friction (Us*Fn)
g = gravitational acceleration
Us = coefficient of static friction
Horizontal component
sinθFn=mv^2/r Eq 1
Vertical component
cosθFn=mg
Fn=mg/cosθ Eq 2
Sub eq 2 into 1
sinθ (mg/cosθ) = mv^2/r (sinθ/cosθ = tanθ)
tanθ mg = mv^2/r
m cancels out
tanθ = v^2/gr
θ = arctan 20.8^2/9.8*88
θ = 26.6 degrees
Am I right up to there?
Now for the second part of the question. Solving for Us.
See diagram for force of friction and horizontal and vertical components
Vertical component
cosθFn - sinθFfr - mg = 0 ( there is no vertical displacement)
Solve for Fn
Fn= (sinθFfr + mg)/cosθ
sinθFn + cosθFfr = mv^2/r
Sub Fn from above
sinθ ((sinθFfr + mg)/cosθ) + cosθFfr = mv^2/r
From here I am unable to isolate Ffr, or cancel out the mass... Help!
Without going through your whole solution, one thing I noticed is that when you solve for Fn, you divided mg by cosθ, but you forgot to divide the first term by cosθ.
EDIT: Also, I don't know why you are not able to isolate Ffr.
Under vertical component?
Vertical component
cosθFn=mg
Fn=mg/cosθ Eq 2
I divide both sides by cosθ here on the left side cosθ cancels out and on the right it becomes mg/cosθ
Is this what you were referring to?
Solve for Fn
Fn= sinθFfr + mg/cosθ
Should be:
cosθFn = sinθFfr + mg
cosθFn/cosθ = (sinθFfr + mg)/cosθ
Fn = sinθFfr/cosθ + mg/cosθ
TomHart said:
Should be:
Ok that correcting that I get the following
sinθ (sinθFfr/cosθ + mg/cosθ) + cosθFfr = mv^2/r
=sinθtanθFfr + tanθmg + cosθFfr = mv^2/r
= Ffr(sinθtanθ + cosθ) + tanθmg = mv^2/r
Ffr = (mv^2/r - tanθmg)/(sinθtanθ+cosθ)
Even if I isolate Ffr here, m is unknown and I haven't been able to cancel it out...
MPat, I see your point. And I wish I had time right now to sort this out, but I have to leave right now. I worked out the problem and, as expected, the mass does cancel out at some point. But I don't have time to compare my solution with yours. I will try to look at it later on tonight. But hopefully, someone will beat me to it.
Thanks for your help! Much appreciated.
$$F_n\cos \theta-F_{fr}\sin \theta=mg\tag{1}$$
$$F_n\sin \theta+F_{fr}\cos \theta = m\frac{v^2}{r}\tag{2}$$
Multiply Eqn. 1 by ##\cos \theta## and Eqn. 2 by ##\sin \theta##. Then add them together. What do you get?
Multiply Eqn. 2 by ##\cos \theta## and Eqn. 1 by ##\sin \theta##. Then subtract the result from Eqn. 1 from the result from Eqn. 2. What do you get?
MPat said:
Solve for Fn
Sub Fn from above
MPat, I think your problem starts when you "solve for Fn". Mathematically, you did it right. But you really still have another Fn term on the right-hand side of that equation because the friction force Ffr is proportional to the normal force Fn. You should make that substitution BEFORE you solve for Fn.
@MPat
If you had followed the simple linear equation elimination approach I indicated in post #8, you would have immediately obtained:
$$F_n=mg\cos \theta+m\frac{v^2}{r}\sin \theta$$
$$F_{fr}=m\frac{v^2}{r}\cos \theta-mg\sin \theta$$
Chestermiller said:
@MPat
GOT IT!...answer is Us = 0.22
I confirm that (0.216).
Related to Banked roads -- circular motion and gravitation
1. What is the purpose of banking roads?
The purpose of banking roads is to allow vehicles to safely navigate turns at high speeds. The banked angle of the road helps to counteract the centrifugal force acting on the vehicle, keeping it from sliding off the road.
2. How does the banked angle of a road affect circular motion?
The banked angle of a road affects circular motion by providing a centripetal force to keep an object moving in a circular path. Without this force, the object would continue in a straight line and not be able to maintain circular motion.
3. What factors determine the ideal banked angle of a road?
The ideal banked angle of a road depends on the speed of vehicles using the road and the radius of the turn. The greater the speed and radius, the steeper the banked angle should be to provide sufficient centripetal force.
4. How does gravity play a role in banked roads?
Gravity plays a crucial role in banked roads as it provides the centripetal force needed to keep vehicles on the road. The banked angle of the road must be carefully calculated to ensure that gravity and the centrifugal force are in balance.
5. Can banked roads be used on any type of vehicle?
Yes, banked roads can be used for any type of vehicle that needs to navigate turns at high speeds. From cars to motorcycles to roller coasters, all can benefit from the use of banked roads to maintain safe and efficient circular motion.
