How Does Temperature Affect Beat Frequency in Organ Pipes?
In summary, the problem is to determine the beat frequency of two identical organ pipes, one at the front and one at the back of an auditorium, with different temperatures. The speed of sound in the pipe is affected by the temperature, resulting in different fundamental frequencies. A formula is needed to calculate the speed of sound at different temperatures.
dimpledur
194
Chapter 12, problem 34. An auditorium has organ pipes at the front and at the rear of the
hall. Two identical pipes, one at the front and one at the back, have fundamental frequencies
of 264.00 Hz at 20.0°C. During a performance, the organ pipes at the back of the hall are at
25.0°C, while those at the front are still at 20.0°C. What is the beat frequency when the two
pipes sound simultaneously? Use 3 significant figures.
Basically, I am not sure whether to assume the organ pipes are closed at one end, and open at the other, or open at both ends. My textbook says it can be both...
Anyways, what I was going to do was just take a ratio of the frequencies.
f1 / f2 = (n1*v1/4L) / (n2*v2/4L)
The only problem here is I have 2 unknowns. I don't know n2 or f2..
I think you would use n1 = n2 = 1 since it mentions fundamental frequency.
Do you understand why the pipe at the back would have a different frequency due to the higher temperature there?
The temperature affects the speed of sound in the air inside the pipe, so v2 will be different from v1. You will need a formula that tells how the speed of sound varies with temperature.
I would first clarify with the instructor or textbook which type of organ pipe is being referred to in the problem. If it is not specified, I would consider both possibilities and provide solutions for each case.
For a closed-open pipe, I would use the formula f = (n*v)/(4L), where n is the harmonic number (1 for fundamental frequency), v is the speed of sound, and L is the length of the pipe. Using the given information, I would calculate the fundamental frequency for the pipe at the back of the hall:
f2 = (1*343 m/s)/(4*L2)
where L2 is the length of the pipe at the back of the hall. Since the pipe at the front of the hall is at the same temperature, its length would also be the same, and therefore its fundamental frequency would also be 264 Hz.
Now, using the formula for beat frequency, fbeat = |f1-f2|, I would find the beat frequency as:
fbeat = |264 Hz - f2|
For an open-open pipe, I would use the formula f = (n*v)/(2L), where n is the harmonic number (1 for fundamental frequency), v is the speed of sound, and L is the length of the pipe. Using the given information, I would calculate the fundamental frequency for the pipe at the back of the hall:
f2 = (1*343 m/s)/(2*L2)
In both cases, the beat frequency would be the same, and would depend on the length of the pipe at the back of the hall, which is unknown. Therefore, I would suggest finding the length of the pipe at the back of the hall or providing more information to solve for the beat frequency accurately.
Related to How Does Temperature Affect Beat Frequency in Organ Pipes?
What is beat frequency in organ pipe?
Beat frequency in organ pipe is a phenomenon that occurs when two sound waves with slightly different frequencies are played simultaneously. The result is an audible fluctuation in loudness called a beat.
How is beat frequency calculated?
In organ pipes, beat frequency is calculated by taking the difference between the frequencies of the two notes being played. For example, if one pipe produces a frequency of 440 Hz and another pipe produces a frequency of 445 Hz, the beat frequency would be 5 Hz.
What causes beat frequency in organ pipe?
Beat frequency in organ pipe is caused by the interference of two sound waves with slightly different frequencies. This interference results in a fluctuation in loudness that is perceived as a beat.
What is the significance of beat frequency in organ pipe?
Beat frequency in organ pipe has practical applications in tuning musical instruments. By playing two notes with slightly different frequencies, musicians can use the beat frequency to tune their instruments to the correct pitch.
How can beat frequency in organ pipe be controlled?
Beat frequency in organ pipe can be controlled by adjusting the frequencies of the two notes being played. By making small adjustments to the frequency of one of the notes, the beat frequency can be increased or decreased.
16K
