Why Is Binding Energy Subtracted in Nuclear Mass Calculations?
In summary, the mass of a nucleus is calculated by adding the masses of protons and neutrons and subtracting the binding energy divided by c^2. This is because binding energy is the energy required to make a nucleus stable and without it, the nucleus would decay. This can be seen in the case of the helium atom, where the mass defect is calculated by dividing by c^2 and subtracting from the total mass of the nucleus.
Alex_physics
The mass of the nucleus is calculated as follows:
mass (nucleus) = [Number of protons * Mass of proton] + [Number of Neutrons * mass of neutron] - [Binding energy/c^2]
Why is the contribution to mass from the binding energy subtracted from the mass of the nucleus rather than being added to the nuclear mass ?
Because that is the definition of binding energy. If you had to spend energy in order to make a system bound, that system would be unstable and decay to the original constituents.
Likes jim mcnamara and Alex_physics
Two hydrogen atoms come together to form a stable helium atom. Surely the mass of the helium atom's nucleus should be the sum of the masses of the two protons and neutrons i.e.
mnucleus = (mproton * 2) + (mneutron * 2)
But, this does not add up to the actual mass of a helium atom. There is a loss of ≈0.0303 amu which is the mass defect. Using Einstein's equation relating mass and energy, E = mc2, we find that the nuclear binding energy is 4.53 x 10-12 J.
Thus in the equation which you stated above, the mass defect is calculated by dividing by c2, thus getting mass back. And to obtain the actual mass of the nucleus it has to be subtracted.
NOTE: By switching the positions of 'binding energy' and 'mass(nucleus)' we get the mass defect equation.
Δm = Zmproton + (A - Z)mneutron - M
Where, Δm = mass defect
Z = number of protons
A = number of nucleons
M = mass of the nucleus.
Likes Alex_physics
What is binding energy in a nucleus?
Binding energy in a nucleus is the amount of energy required to completely separate all the protons and neutrons within an atomic nucleus. It is a measure of the strong nuclear force that holds the nucleus together.
How is binding energy calculated?
Binding energy is calculated using the famous equation, E=mc^2, where E is the binding energy, m is the mass defect (difference between the mass of the nucleus and the sum of its individual parts), and c is the speed of light.
What is the significance of binding energy?
Binding energy is significant because it is responsible for the stability of atomic nuclei. The stronger the binding energy, the more stable the nucleus is. It also plays a role in nuclear reactions, such as fusion and fission.
How does binding energy affect the mass of a nucleus?
Binding energy is a form of energy, and according to Einstein's famous equation, E=mc^2, energy and mass are equivalent. Therefore, the binding energy of a nucleus contributes to its overall mass.
Can binding energy be measured directly?
No, binding energy cannot be measured directly. It can only be calculated based on the mass of the nucleus and the mass defect using the equation E=mc^2. However, its effects can be observed in nuclear reactions and the stability of nuclei.
