Calculate Length of Unwound Wire with Angular Velocity and Spool Radius
  • Thread starter Thread starter xortan
To calculate the length of wire unwound from a spool with a radius of 48.0 cm making 2.1 revolutions, the key is to focus on the distance covered per revolution. Each complete revolution unwinds a length equal to the circumference of the spool, which is calculated as 2π times the radius. Therefore, for 2.1 revolutions, the total length of wire unwound is 2.1 times the circumference. The discussion emphasizes that velocity is unnecessary for this calculation, and the focus should remain on the length of wire. Simplifying the approach will yield the correct answer without unnecessary complexity.
xortan
1. A spool of wire is rolled out along a level floor. If the radius of the spool is 48.0 cm and the spool makes 2.1 revolutions, what length of wire (in cm) is unwound?
velocity = (angular velcity)(radius)
2.1 rev * 2pie radians/rev. I know the revs will cancel and i will have 4.2pie radians
Since velocity = Distance/time i will say time=1 min then i get distance=(48.0)(4.2pie) which is 201.6pie cm/min and i will divide this by 60 to get 3.36pie cm/sec
Am i going in the right direction? I don't know if what i did so far is right or if I am missing something, thanks in advance for the help this would really help me for the midterm i got on tuesday
There's nothing in this problem that gives velocity or asks for it. All that's needed is the length of wire that unwinds from the spool.
BTW, the name of this Greek letter, \pi, is pi, not pie. A pie is something you can eat.
Mmm... I sure wish I had that many pies per second...
A few hints:
Find how much would be left behind with one revolution. This should be simple, and you have all the variables necessary. But the spool makes 2.1 revolutions. How much would then be left behind?
You are making it more complex than it needs to be. Who cares how fast the thing goes? Besides, you don't have the information to do this. You only really need how far it went.
I tried to combine those 2 formulas but it didn't work. I tried using another case where there are 2 red balls and 2 blue balls only so when combining the formula I got ##\frac{(4-1)!}{2!2!}=\frac{3}{2}## which does not make sense. Is there any formula to calculate cyclic permutation of identical objects or I have to do it by listing all the possibilities? Thanks
Essentially I just have this problem that I'm stuck on, on a sheet about complex numbers: Show that, for ##|r|<1,## $$1+r\cos(x)+r^2\cos(2x)+r^3\cos(3x)...=\frac{1-r\cos(x)}{1-2r\cos(x)+r^2}$$ My first thought was to express it as a geometric series, where the real part of the sum of the series would be the series you see above: $$1+re^{ix}+r^2e^{2ix}+r^3e^{3ix}...$$ The sum of this series is just: $$\frac{(re^{ix})^n-1}{re^{ix} - 1}$$ I'm having some trouble trying to figure out what to...
