Calorimetry help (chemistry)
In summary: Yes, that is a good way to summarize it. In summary, the lab consisted of 3 reactions: reaction 1 was the heat of dissolution of solid sodium hydroxide, reaction 2 was the heat evolved as the sodium ion in sodium hydroxide is displaced with the hydrogen ion, and reaction 3 was the heat of neutralization as a hydrogen ion and hydroxide ion undergo a neutralization reaction to produce water. The net ionic equations for reactions 2 and 3 represent the sources of heat in each reaction.
Draggu
102
Hi, here is a basic summary of what we did in a lab; there were 3 reactions:
The procedure:
Reaction 1: Solid sodium hydroxide dissolves in water to form an aqueous solution of ions.
NaOH(s)-> Na+(aq) + OH-(aq) ΔH1=-34.121kJ
Reaction 2: Solid sodium hydroxide reacts with an aqueous solution of HCl to form water and an aqueous solution of sodium chloride.
NaOH(s) + H+(aq) + Cl-(aq) -> H2O + Na+(aq) + Cl-(aq) ΔH2=-83.602kJ
Reaction 3: An aqueous solution of sodium hydroxide reacts with an aqueous solution of HCl to form water an an aqueous solution of sodium chloride.
H+(aq) + OH-(aq) + Na+(aq) + Cl-(aq) -> H2O + Na+(aq) + Cl-(aq) ΔH3= -50.2kJ
The ΔH values were calculated by dividing the heat gained by the number of moles (each reaction had 0.05moles of NaOH)
The problem:
Net ionic equations for reaction 2 & 3:
2: NaOH(s) + H+(aq) -> H2O + Na+(aq)
3: H+(aq) + OH-(aq) -> H2O
i) In reaction 1, ΔH1 represents the heat evolved as solid NaOH dissolves. Look at the net ionic equations for reactions 2 and 3 and make similar statements as to what ΔH2 and ΔH3 represent.
ii) Compare ΔH2 with (ΔH1 + ΔH3). Explain in sentences the similarity between these two values by using your answer to #5 above.
Attempt at answering:
i) Firstly, ΔH2 represents the heat evolved as the hydrogen ion displaces the sodium ion, creating a single displacement reaction. ΔH3 represents the heat evolved as the hydrogen and hydroxide ion form water via a neutralization reaction.
ii) ΔH2 is equal to (or supposed to be, this is a source of error while calculating) (ΔH1 + ΔH3). The similarity between these two values is that .. (this is where I get confused!)
These were two different experiments, yet what you state is in both cases heat evolved is just that of the neutralization reaction.
Think again about what must happen in the first case (that is, second reaction).
I thought about it and I'm still hazy by what you mean. "both cases heat evolved is just that of the neutralization reaction."
I agree that taken out of context it doesn't make sense, but in the context in which I wrote it I still think it is OK. But let's try to reword it, and remember that what I wrote refers to the quote from your post:
The way you wrote it there is no difference between sources of heat evolved in both experiments - if you try to write reaction equations for each process as described, you will see that in both cases it is H+ + OH- -> H2O. This is obviously wrong - you are omitting something.
Hi, I'm still unsure what I am omitting.
Part I: I assume reaction 3 is the energy/heat gained as the H and OH molecules react because they are the only two in the net ionic equation.
Part II:
Perhaps I'm not understanding the purpose of the net ionic equations other than that if there is a product created, it creates energy and the net ionic equation eliminates a substance that is on both sides.
This is exactly what I wrote in a word file, for the lab:
It appears that (H1 + H3) is very similar to H2. Using logic, H2 should be equal to (H1 + H3) because reaction 2 undergoes both reaction 3 and reaction 1 at the same time, as shown from the net ionic equations.
The similarity between these two values is that in reaction 1, NaOH(s) dissolves into Na+(aq) + OH-(aq) ions and in reaction 3, hydrogen and hydroxide ions form H2O. In reaction 2, both of these reactions are occurring during the single displacement reaction. The solid NaOH dissolves into Na+(aq) and HOH, and the H+ ions and OH- ions eventually form water too, during the single displacement reaction. Thus, reaction 2 will have the same energy as the sum of reaction 3 and reaction 1.
Google heat of dissolution or heat of solvation.
I googled it and even searched through threads on this forum, but I still can't get a solid answer.
What I know is H1 + H3 = H2
Why? I don't know. I don't understand why they add up. I also don't understand what I am omitting in the 3rd net ionic equation.
In the lab it says to explain these using the net ionic equations only.
What about
NaOH(s) -> Na+(aq) + OH-(aq)
methods
When solid NaOH dissolves, heat evolves. That's your 1st experiment - heat of dissolution. When dissolved NaOH reacts with acid (neutralization), heat evolves - that's your 3rd experiment, heat of neutralization.
What are sources of heat in your 2nd experiment?
Alright, so would this be fair to say?
Reaction 2 represents the heat evolved as the sodium ion(s) in sodium hydroxide(s) is displaced with the hydrogen ion(aq), producing water and a sodium ion(aq). It also represents the heat evolved from the dissolved NaOH and the neutralization of water.
Reaction 3 represents the heat evolved as a hydrogen ion and hydroxide ion undergo a neutralization reaction, producing water.
The solid NaOH dissolves into a liquid NaOH in reaction 1. This is the heat of dissolution. In reaction 3, the reaction undergoes a neutralization reaction, creating water. In reaction 2, the NaOH dissolves into a liquid and also forms water, thus, both reactions occur doing reaction 2, making H2 = (H1+H3)
Right :smile:
methods
1. What is calorimetry and how is it used in chemistry?
Calorimetry is a scientific technique used to measure the amount of heat released or absorbed during a chemical reaction. It can also be used to determine the specific heat capacity of a substance. This information is important in understanding the energy changes that occur in a chemical reaction.
2. How does a calorimeter work?
A calorimeter is a device used to measure heat changes. It typically consists of a container, often made of a thermally-insulating material, and a thermometer. The substance or reaction being studied is placed inside the container and the change in temperature is measured using the thermometer. The heat change can then be calculated using the formula Q = mcΔT, where Q is the heat change, m is the mass of the substance, c is its specific heat capacity, and ΔT is the change in temperature.
3. What is the difference between bomb calorimetry and coffee cup calorimetry?
Bomb calorimetry involves placing a substance in a sealed, pressurized container and measuring the heat change as it undergoes a combustion reaction. This method is often used to determine the energy content of food and other organic materials. On the other hand, coffee cup calorimetry is a simpler method that involves mixing two substances together and measuring the change in temperature. It is commonly used in chemistry labs for experiments that do not involve combustion reactions.
4. What are some common sources of error in calorimetry experiments?
Some common sources of error in calorimetry experiments include heat loss to the surroundings, incomplete mixing of substances, and inaccuracies in temperature measurements. Other factors that can affect the results include the presence of impurities in the substances being studied and variations in the specific heat capacity of the substances.
5. How can calorimetry be used to determine the enthalpy of a reaction?
The enthalpy of a reaction can be determined using calorimetry by measuring the heat change during the reaction and using the formula ΔH = Q/n, where ΔH is the enthalpy change, Q is the heat change, and n is the number of moles of the substance. This method is often used in thermodynamics to study the energy changes that occur in chemical reactions.
